95 air conditioning into an 88
Old Nov 22, 2007 | 04:47 AM
ozziesironmanoffroad's Avatar
would this work? putting a complete a/c system from a 95 truck to my 88. im sick of no a/c, and want a/c before summer hits again. any help would be appreciated
Old Nov 22, 2007 | 10:55 AM
idanity's Avatar
good question, as i thought of it before, but alas just bought a 4x w/A.C. since its a huge job.
they do make aftermarket A/C kits that fit under the dash. a self contained unit.
for you to do it right would take alot of work, and i.m.o. the freon systems would be worth it. (mine blows at 27degrees at the vents, and yes, i can see my breath in July.
im sure retro fitting the newer dash would be worth photographing and posting your work (especially if it turns out to be easy) would be fallowed by many.
or do you want to stealth it in your existing dash (adding the toggle button, vent hookins etc.)
i can take pics of my stock setup today (*im removing the dash this weekend) if you want, i will post em.
Old Nov 22, 2007 | 11:09 AM
sure sounds good. i rolled my truck, and totally replaced the cab, by myself with nothing but hand tools and a tag along. so if i can do that in 3 weeks, i figure the a/c will be nothing. im wondering if i would have to swap harnesses and everything.
Old Nov 22, 2007 | 01:48 PM
anotherjeff's Avatar
Retrofitting A/C is pretty straightforward. It was a dealer installed option, so the wiring harness is already in place. The evaporator, expansion valve, and electrical stuff are all contained in the ducting that swaps out the dummy duct under the dash. The holes in the firewall for the hoses have rubber plugs.
This is true with '89-'95 PU's. The '88 model may have some minor differences.
Old Nov 22, 2007 | 02:01 PM
idanity's Avatar
surely someone has done this than.
i would check google to see. but im halfway into my entire dash out, and its a big job sofar.
i will take a pic after lunch (now)
Old Nov 22, 2007 | 04:46 PM
idanity's Avatar
looks very cumbersome just to get to the heater core. (which i dont even know where it is yet)
Old Nov 22, 2007 | 05:49 PM
paxil4x4's Avatar
Drama Queen/Banned
I put factory air in my 85 and it was cake. The plugs are already for you to use under the dash and you only have to remove the glove box and peel the carpet back. You will need to drill 3 holes with a hole saw but even those are marked at the factory with dimples. See partial write up in the Wiki
Retrofitting out a new model truck would be a PITA just find the same generation truck
Swim
9
Jan 4, 2016 10:47 AM
Tacoma1313
Aug 17, 2015 05:44 PM
94ofCanada
Aug 14, 2015 06:37 AM
Sidherish
Aug 2, 2015 01:42 PM
terminator
Jul 27, 2015 07:13 PM
