95 4Runner--Rough idle, loss if power,
Old 07-27-2016, 06:16 PM
Dakota6078's Avatar
95 4Runner--Rough idle, loss of power,
PLEASE HELP! Stumped and need advice. 95 4Runner 3.0--- Rough idle at speeds under 55. No power unless I take it out of overdrive and around 60 mph I can put it back into overdrive and it runs okay. Still skips but not as bad. Doesn't idle as rough in neutral but still skipping. When the outside temperatures are cool (early mornings--late nights) it runs alright. Has power and I don't have to take it out of overdrive. But the hotter the outside temperatures are the worst the truck runs. It acts like it's only running on five cylinders. It does have alot of blow back out of the valve cover on the driver's side. Everything on that side is soaked with oil. I've replaced cap, rotor, plugs, wires, cleaned maf, timing belt, water pump. Thxs
Joey22r
02-08-2016 05:08 PM
Mikkydee
01-27-2016 03:23 PM
PAVEYOTA
07-21-2002 08:25 AM
Paul S
06-20-2002 05:07 PM
Quick Reply: 95 4Runner--Rough idle, loss if power,
