95 4rnr 22re spark plugs way light color
Old 01-04-2006, 10:52 PM
Kurt's Avatar
Plugs this light on an old carb engine would send up a BIG flag. Hardly any tan color and only on one side, mostly white. Is this normal for these?? The thing runs great. I don't think the mileage is where it should be, getting about 18 somtimes less. Any thoughts,, Thanks!!!!
Old 01-04-2006, 11:01 PM
marko3xl3's Avatar
You are probably running way lean...
Old 01-06-2006, 06:54 PM
84sr5yoty's Avatar
Definitely running too lean. If the motor runs good with no check engine light, it’s probably a vacuum leak. Check all the vacuum hoses and diaphragms.
Old 01-06-2006, 11:09 PM
kyle_22r's Avatar
the 22R-E is a very lean running engine, you'll be fine unless you're pinging. supposedly the TCCS 22R-E engines('89-95) were leaner running than the earlier types with toyota EFI.
Charecter1
11-06-2023 10:08 AM
06-01-2021 01:51 PM
coryc85
09-09-2015 06:24 AM
smiley52
07-11-2015 05:16 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 95 4rnr 22re spark plugs way light color
