'94 22re power steering idler pulley?
Where can I get his damn pulley without it being $150?
how is it even possible for a pulley to be this expensive
You could try to use s different pulley provided s few things are the same.
The shaft of both the pump and compressor would need to be the same.
The diameter of the pulley would need to be similar. Too small and your steering will be hard, too large and you could blow out things from over pressure.
https://www.yotatech.com/forums/f116...pulley-197631/ The least painful solution (dollar wise) for most people is to buy a replacement bearing. I think it was around $20 at NAPA. Since you don't have the old pulley, there is a pn for a Dayco pulley in the posted link, but it is slightly larger and requires a longer belt.
87tyota77
04-22-2020 07:00 AM
cgill87
06-22-2016 05:07 PM
Casey7762
06-05-2016 10:38 AM
sacramentoyota85
05-05-2016 11:04 PM
