93 yota 4x4 22re brake light
Old 08-13-2015, 05:20 PM
anndel's Avatar
I have a weird situation that when I rev the engine up to 3,000 rpm (moving or standing still), the check brake light comes on once I a while. I replaced the master cylinder and bled the system 2 years ago and this issue popped up last week. Anyone experienced this? Thanks
Old 08-13-2015, 10:49 PM
James Woods's Avatar
When you have the engine off and you turn the key on, does the battery light come on? To me, its sounds like your charging system but maybe your battery light is burned out or not working.
Old 08-13-2015, 11:26 PM
anndel's Avatar
Checked it with ignition on and engine not running, check brake , engine , battery and oil lights all light up.
Old 08-13-2015, 11:50 PM
wyoming9's Avatar
Red face
Check your brake fluid level !!
As the front pads wear the fluid level drops.
Old 08-13-2015, 11:53 PM
anndel's Avatar
OK thanks I will
Old 08-14-2015, 08:52 AM
Or that, guess I jumped the gun a bit and assumed you had already done that.
Old 08-14-2015, 08:55 AM
anndel's Avatar
Thanks, brake fluid is at the max line.
Old 08-26-2015, 06:36 AM
DukeOfHazard's Avatar
This help me too, thank you, my "brake light" would turn on when I accelerate or braking, but also found out that my front rotors are warped too.
Old 08-28-2015, 04:56 AM
AKHeathen's Avatar
any problems with the braking? wheel sensor on the rear diff good?
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
colinmil
07-06-2015 04:03 PM
Jnkml
07-06-2015 01:20 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 93 yota 4x4 22re brake light
