93 Toyota 4cyl pickup stalling out.
Was in McDonalds drive thru. Truck idled down and acted like it was going to cut off. Which it did. Took me two tries to turn back on but would act like it was Jumpn forward like someone not knowing how to drive a stick shift. If that makes sense. All the gears locked up and could not shift anything at all. The idling stayed low and had to keep slight pressure on the gas. After the incident it was fine. Hasn't done it again. Any ideas on what it could be?
Staff
Not sure what would cause that. I would check to see if the Seat Bushing in the shifter is okay. Start with the easy things. My next check would be if the Master and Slave Cylinders are all right and then move on to the clutch.
Clutch was just replaced. And today is the fourth time that I have had to fill up the clutch reservoir. There are no leaks seen on the ground. So I have no idea on where the fluid is going. It has not stalled again but i don't know if it's because of the slave cylinder. But it was replaced with the clutch too.
WTB[MidAtl]: Forward shift tcase shifter base and shifter
I8URSVT
03-28-2016 08:37 AM
ZRTALPHA1
02-21-2016 12:12 PM
