93 PU sr5 brakes not building pressure.
Old 04-29-2015, 03:25 PM
Squigglez's Avatar
I've recently change the brake lines on my pickup due to rust the lines that were changed are the two that run front the front to the back, into the LSPV.
I started bleeding the lines all fine and dandy until I tried pumping the brakes and there would be resistance but pressure wouldn't build.
I did a bench bleed of the master cylinder and made sure there were no more leaks, which I found there were none.
Starting to think its the LSPV but not sure.
Old 04-30-2015, 10:38 AM
the_supernerd's Avatar
Are you saying that the brakes kind of work but the pedal slowly sinks to the floor? Did you bleed the LSPV? If so, and you are getting clear fluid at all the wheels, then it could be the master cylinder. Sometimes bleeding the brakes on an old master cylinder can finish it off, or I have had bad re-maned cylinders, also.
Old 05-01-2015, 09:32 PM
Kiroshu's Avatar
Air in brake hydraulic system.
Faulty Master Cylinder.
Incorrectly installed front brake calipers.
Old 05-02-2015, 05:48 AM
Squigglez's Avatar
I haven't tried bleeding the LSPV. Didn't know you could. Maybe I should try that first.
Old 05-02-2015, 05:53 AM
wyoming9's Avatar
Red face
It can be as simple as one poor connection or a bad bleeder valve that has a piece of rust.
I have done numerous brake hydraulic rebuilds due to rusted lines my one and only attempt to bleed the LSPV was so very expensive
Then in 20 plus year old vehicles I wonder how many really still work
Living in the great rust /Liquid brine belt is so very hard on brake lines
Old 05-02-2015, 11:17 AM
Squigglez's Avatar
I bleed the LSPV and there was a bunch of air in it. Brakes are fine now. Thanks for the help!
Old 05-02-2015, 07:47 PM
Kiroshu's Avatar
Glad you got it fixed.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
Quick Reply: 93 PU sr5 brakes not building pressure.
