93 pickup turn signal problem
Old 12-07-2006, 05:49 PM
want2wheel's Avatar
I have a 93 pickup that the turnsignals do not work. I replaced the switch, and still have the problem. When you turn on the driving lights they all light up, and when you turn the signal lever they do nothing. Any advice would help out a bunch. Thank You, God Bless.
Old 12-07-2006, 05:54 PM
Elton's Avatar
fuses check the bulbs ?
Old 12-07-2006, 06:14 PM
want2wheel's Avatar
I have checked all of the fuses, and replaced most of them. When I got the truck the turnsignal was broken, and needed to be replaced, and has not worked. I will look at the bulbs tomorrow. Are they duel element?
Old 12-07-2006, 06:16 PM
Elton's Avatar
no there not
Old 12-07-2006, 06:17 PM
toyota_mdt_tech's Avatar
Check the hazard switch. If its failed in a way, the singals become inop. Maybe its unplugged. Anyone just have the dash apart recently? If its all plugged in, try turning the hazards on and off a bunch, this can sometimes get it to work, but still needs to be replaced.
Old 12-07-2006, 07:32 PM
JamesD's Avatar
You have a bad ground, rusted taillight sockets or a trailer harness going bad.
James
Old 12-08-2006, 04:34 PM
want2wheel's Avatar
The hazard switch does not work. I cannot get it to do anything. I guess that is the part that I need to replace right? Is there a way to test that circuit from that point? Will that flasher come straight out of the dash or is there a trick? Thank You for the help. Rob
Old 12-08-2006, 04:43 PM
want2wheel's Avatar
Well, that is now fixed. The kid that owned the truck before me just threw the dash back in it to sell it quick. I guess that he did not want to plug anything back up. That is what was wrong with my clock as well. By the way it is really cold outside. I think that it may snow. Thank You very much, and God Bless.
Old 12-08-2006, 04:56 PM
Elton's Avatar
great it was something simple glad we could help
Old 12-08-2006, 07:35 PM
So was the hazard switch unplugged? Pretty good, aint I
bigblue82
10
07-06-2015 08:27 AM
aciorba23
06-29-2015 04:18 PM
infinityisfive
06-16-2015 06:51 PM
LSUMatt1514
04-17-2003 07:43 AM
CLin9383
13
07-09-2002 02:45 PM
Quick Reply: 93 pickup turn signal problem
