'93 Dually Pickup EGR Valve Replacement
Hello all,
this is my first post. Hoping someone out there can help me. I deleted the EGR Valve a while ago, but now I want to find a replacement. The exhaust is too rich and stinks, and the check engine light wont turn off and it is reading EGR Valve.
The OEM part number is 25620-65022. Can't find it anywhere. Is there any upgraded or improved EGR Valve out there that might work. I got a Chinese one from Federated Auto but it would have needed some significant re-plumbing/re-routing solid tubing to attach it.
Let me know!
Thanks,
Nico
Let me know!
Thanks,
Nico
I believe the EGR valve 22RE Performance sells should work for your application. It is spendy, but should be a quality part.
You can contact them if you are unsure of the fitment.
https://22reperformance.com/intake-e...cuum/egr-valve
If you replace your EGR valve, you'll also need the EGR gas temp sensor to go with it. Most folks who delete the EGR also trash the Modulator, the gas tube, and whole bunch of other very hard to replace parts. You might have more luck in a salvage yard.
The good news is that your missing EGR has nothing to do with the smell of your exhaust. The EGR valve doesn't affect mixture, and while the deletion really raised your NOx output, all of the NOx compounds are odorless (but still dangerous). Replacing your EGR system (even with all the parts) won't solve your problem. It lies elsewhere.
Good luck!
The following users liked this post:
JoeS (02-17-2023)
Scope103 question
Hey Scope103,
in response to your comment "Replacing your EGR system (even with all the parts) won't solve your problem. It lies elsewhere." I am wondering what repairs and changes need to be made to my ol' truck to improve the smell of the exhaust (and if possible the fuel efficiency of it - though the big uhaul box on it doesn't help fuel consumption). Do you mean O2 sensor, or what other systems and effect the exhaust.
I will print all of your comments and take them to my mechanic friend (from Honduras) He doesn't speak great english, but I will translate. He is a really fantastic and serious professional mechanic!
Thank you for your time. It is very helpful to me!
Nico
Nico
22RE - No luck!
Hello old87yota et al,
here is the response from 22RE parts: "sorry, looks like toyota has discontinued that part number. I do not have any good leads for you on an alternative since you are a V6 engine and we do not deal with those at all, so I don't know if there is a good aftermarket alternative. Sorry we couldn't help"
Any ideas now?
Thanks,
Nico
Any ideas now?
Thanks,
Nico
