91 Toyota SR5
Unfortunately I haven't put the rotors on yet. After watching some youtube videos I realized I need new locking washers and I want to change the seal on the back of the hub. So I ordered them since I can't find any parts local. If they get here by sunday I will get them done then. I will let you guys know how it went.
I figured out my problem with the hubs. They were bought from a fellow member who advised me he found them in the junkyard and he didn't know if they even worked. So I don't blame him at all. There are 26 splines like it should have for a ifs truck. But the hub part is from a sfa truck. I noticed the raised grips on the dial and then I found out the clutch on the sfa is longer. Mine is longer and won't pull back far enough to disengage. So off to the junk yard for some clutches. I will use the same face plate since they are interchangeable.
I found a great write up that explains the differences. I have included some pics to show what mine came with.
http://www.se4rj.com/forum/showthread.php?t=293
Longer clutch
Dial
Longer clutch
Dial
Anyone here about changing the multipiece driveline to a one piece. My carrier bearing is shot and I was planning on changing it and my buddy told me I should just get a single line.
I just installed mine yesterday. A one-piece requires parallel flanges. I ordered 9 degree shims to twist my rear diff down to make the flange vertical, but I don't have them yet. I drove a few miles yesterday and had no noticeable vibration, but I didn't get past 60 mph. I'm sure I would shorten the lifespan of my u-joint dramatically if I continued to drive like that.
#25
I have been gathering the parts for the new rotors. But it seems like not one place has all the parts. I still need new seals for the back of the axle. Here's a pic of the parts so far for new rotors and manual hubs. I am still looking for the pawl for the locking hub, no luck at the junk yard.
While I am waiting I got started with repainting the hubs.
And just for fun,
And just for fun,
#26
I am starting to realize what everyone says about the 3vze motor. It is a pain to work on but when I realize it is 20+ years old and that seems to be the big problem. I found the fuel pressure damper to be leaking the gas. After tracking down all the needed gaskets, I started the job of replacing the damper.
4 broken vacuum lines, 1 broken BVSV, power steering pump, still need the power steering pump idle up valve, 1 new power steering hose line, and now a check engine light I can finally drive the truck without leaking gas. Oh and the damper.
It took almost a week to get it done but I drove it out to the Mojave Desert this weekend and it did great. No real 4 wheel drive trails, but a lot of off road.
Field Road out in Mojave looking for Agates
Still need to do the brakes. I just got the hub seals so I have everything. Also still looking for the prawl that goes into the manual hubs. No luck at the junk yard here.
#27
Did you replace the dust seal on the back side of the knuckle before installing your CV axle? I have a 92 4Runner and I cant find this seal. Toyota said they superceeded to another seal that is impossible to use.
#28
My new cv axles had the dust shield installed on them. The first set I got was bent so I sent them back. Summit Racing overnighted me a new set and they too had the dust shield installed.
#29
So you don't have a another seal pressed into the back side of the knuckle where the brass bushing is? That is the seal I am having a hard time finding. Perhaps they eliminated it and use a seal on the axle now?
#30
I didn't look at the back of the knuckle. I saw the new seal on the cv axles and didn't think they would of had another on the back of the knuckle.
So while looking for a set of hubs, I found a guy parting out his 4runnner. He has the hubs and a non add axle tube. I read that they can be easily swapped out to get rid of the add system. I was wondering that if I got rid of it how would I make the little light on the dash still come on when the tranny is engaged but since there will no longer be a add tube, how will it work. Or what can I do to make it work.
#31
I have been enjoying my truck for a little while now and now another problem. It just started one day where it was very sluggish and it wasn't shifting into overdrive. I soon realized that I had also lost 1st gear. So I have been driving it around in 2nd and 3rd gear only. After checking everything easy to get to no check engine or trans light on I think one of my shift solenoids are out. I think number 2 is stuck. I found all 3 today at the junk yard and I tested them. They are all working great. Unless anyone has another suggestion, I am thinking htis is my problem. Any ideas?
#32
