**89silverpu's e-locker retrofit build** - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-02-2009, 10:24 PM   #1 (permalink)
89silverpu's Avatar
Location: Vacaville/Sierra Nevada Mountains, CA/ UNLV (Las Vegas), NV
Finally got to retrofitting my e locker with 4.88's into my truck. I had a local shop cut, weld, drill, and tap everything since I don't have the tools necessary to do that.The simple version...
EDIT:
Tools/parts you will need:
- e-locker third from a TRD 4x4 Tacoma or a 4runner with the factory e-locker
- Toyota factory e-locker gasket to mark where to cut out and drill holes
- Toyota factory e-locker studs (long)
- Electronic actuating harness/switch (got mine from 12voltguy.com....highly recommended)
- 17/64" drill bit
- 8mmx1.25 tap
- I had a local welding shop modify my axle, but if you're going to do it yourself...Welder, plasma cutter, drill press (could use cut off wheel instead of plasma cutter just takes longer)
- 4'' angle grinder
- Good file to even out surface after adding extra bead of weld
- spray paint
- brake clean
- RTV Grey gasket material
- Tools necessary to remove rear axle assembly
Note: if you are setting up your own gears, you'll need a regular 8" ring and pinion in whatever gear ratio, but you'll need an e-locker specific install kit.
Take the axle out...
After taking the third out, take out the three studs you will not be using...
Put on the toyota factory gasket and mark where the holes need to be drilled and what needs to be cut out...
(next 2 images taken from 4x4wire.com write up)
Cut, drilled, and tapped with extra material added on the outside of the newly drilled and tapped holes for more surface for the gasket to seal...
E-locker third slid into place after cleaning all the metal shavings out really well and coating the rim with ultra gray gasket maker (axle must be in locked position)...
All painted up...
Now tomorrow I'll finish getting the axle back in the truck, bleed the brake lines, hook up the wiring harness, and I'll be ready to go. Gotta break the new gears in nice and slow. I'll post up finished pictures when I'm done.
Sorry for the quick write up, I'll go into more detail when I have more time!!
__________________
'89 Beater Jeep Eater in progress
4.88's, TRD e-locker, Dual Cases, 33's, Armored,
Tread Lightly
Mixchallenge.info
89silverpu is offline
Old 06-02-2009, 10:36 PM   #2 (permalink)
scuba's Avatar
DAMN !!!
Congrats man !!
You scored on that setup
__________________
Screw you guys I'm goin to TTORA
scuba is offline
Old 06-03-2009, 12:52 AM   #3 (permalink)
space-junk's Avatar
oh man, your gonna love those 4.88s...
congrats on gettin a nice score...
__________________
Trailer Re-Build - Check it out!!!
Quote:
Originally Posted by Junkers88 View Post
From the back of the crowd you hear a slightly slurred Clint..."Hell that ain't nothin'. Give me the damn keys and hold my beer, I'll show you how to kill a Yota."
1990 4RUNNER
V6 & 5spd. | Custom Cat-Back | Magnaflow Muffler | ProComp Light bar | OME 901HD springs | Cobra 19 Ultra III
Pro comp Driving Lights | 33x10.50 BFG A/Ts | 4.88 Factory Gears | Hi-Lift Jack
space-junk is offline
Old 06-03-2009, 07:04 AM   #4 (permalink)
89silverpu's Avatar
Thanks guys, after I get this all taken care of, I just gotta put my front 4.88's in and break the gears in then I'm plannin a big wheelin trip up to Eagle Lakes/Fordyce at the end of June to pop it's cherry
__________________
Tread Lightly
Mixchallenge.info
Old 06-03-2009, 09:13 AM   #5 (permalink)
RMA
Dude Great job , looks good .
Now I want one...
Hey I see they also added a bit of material on the right for the 2 bolts.
again Nice Job...
__________________
'89 2wd X-tracab,W55,22re,My DD
'94 SR5 4Runner 4x4,A340H, 3VZE,Alpine deck,Wifes DD
'88 SR5 4runner ,A341E,1UZ-FE,kenwoodVZ907,
XRC8, Homemade Roof rack.33x10.50,15 KM2
1" home made body lift, BJ spacers ,CB, rear disc brakes ,lockright rear.sky ebrake,truetrac front.
My swap thread
http://www.yotatech.com/f161/1uz-fe-...0-3vze-185324/
RMA is offline
Old 06-03-2009, 11:41 AM   #6 (permalink)
RustBucket's Avatar
Send a message via AIM to RustBucket
Did the pound the back of the housing out a little bit to clear the larger gear?
__________________
Rust-Free '88 Runner. Stay-at-home truck.
RustBucket is offline
Old 06-03-2009, 12:31 PM   #7 (permalink)
toyNG's Avatar
I'm so jealous!!!!
__________________
1986 pickup 4x4 SR5, 5-spd, 33x10.5 BFG KM1 muds, 2" body lift, front and rear lockrights, 4.88s, 4.7 t-case with Dave'z twin stick, BudBuilt crossmember with 1" drivetrain lift, Downey grille guard and skid plate, TG sliders
Still needed: rear bumper (Marlin, TG, or Dave'z)
toyNG is offline
Old 06-03-2009, 01:36 PM   #8 (permalink)
89silverpu's Avatar
Quote:
Now I want one...
again Nice Job...
Yeah I forgot to mention that too. You have to add the extra metal out there to make room for the stud hole and to add more material for the gasket to bond too. Thanks!!
Quote:
No I pounded down the bottom of the "pumpkin section" to clearance for a bolt that sticks out a little farther than the stock third. The gears are the same size, 8''.
Quote:
Originally Posted by toyNG View Post
I'm so jealous!!!!
haha you've got 4.7's...we'll call it fair
__________________
Tread Lightly
Mixchallenge.info
Old 06-03-2009, 03:25 PM   #9 (permalink)
Lama glama's Avatar
Man, that looks great! Thanks for the good pics! I really want to do this mod.
__________________
Brian
1991 Ext cab 4x4 3.0 5spd
3.4 swap in the works!!!
Lama glama is offline
Old 06-03-2009, 03:31 PM   #10 (permalink)
Junkers88's Avatar
Man that looks great!!! CONGRATS!!!!!!
I want to do this when I regear to 4.88's front and rear but finding an E-locker for less than 800$ is almost impossible out here.
__________________
RB4R Life Member.
1989 SR5 4runner. Tread Wright 31/10.50/15's. 4.56 thirds, an Aussie in the @$$, Budbuilt plate, Marlin Crawler front, modified MC rear, Supra MAF conversion, ZUK coils in the rear and 4crawler BJ's in the front, LCE header.
Junkers88 is offline
Old 06-03-2009, 04:20 PM   #11 (permalink)
RMA
junkers there is a guy on ebay that always has them for $350, somtimes less $300
__________________
My swap thread
RMA is offline
Old 06-03-2009, 05:23 PM   #12 (permalink)
874runnersr5's Avatar
Man im jealous,
looks good dude keep up the great work
__________________
87' 4runner Sr5 : 22re : 5spd : 32x11.5 BGF Km2 : Cragar 15x8 soft 8s : TG Rock Defense Front Bumper : Sirius radio : Optima Red Top : Pioneer system : Engnbldr tchain kit : Downey 3" leafs : Diff breather : Tube doors : Bikini Top
Calgary Toyota Association
I <3 my Toyota
874runnersr5 is offline
Old 06-03-2009, 08:14 PM   #13 (permalink)
89silverpu's Avatar
I just got in from finishing it up and takin it for an easy drive to break the gears in I'll have final pictures up on here as soon as they are uploaded from photobucket
Quote:
No problem I had a lot of fun....as well as frustration lol
Thanks!! I know, they are expensive, I got really lucky with such a good deal on the new gears and everything too!
Quote:
Originally Posted by 874runnersr5 View Post
Man im jealous,
Thanks!! Too bad you didn't wanna trade your 4runner for the third member
__________________
Tread Lightly
Mixchallenge.info
Old 06-03-2009, 08:32 PM   #14 (permalink)
89silverpu's Avatar
Haven't hooked up the wiring harness permanantly, just enough to unlock the axle so I can drive, I'll get that all hooked up when I have more time, this took a couple days to put together inbetween working and training. On to the pics...
Painted all nice and pretty...
__________________
Tread Lightly
Mixchallenge.info
Old 06-03-2009, 08:36 PM   #15 (permalink)
Staff
UKMyers's Avatar
Send a message via AIM to UKMyers
Sweet man congrats.. when we going wheeling? What do you think of the 4.88's so far?
__________________
2006 Tundra Double Cab TRD Offroad 4.7 IForce Bilstein 5100's, 285 BFG's, Panther Wheels, Limo Tint
1994 4-Runner SR5 5 Speed SASed, Detroits, Armored, Dual Cases, 37" MTR's Build up http://www.yotatech.com/showthread.php?t=104000
Need Toyota Parts? www.davezoffroadperformance.com
Quote:
...why does my IFS have no flex, and what can I do to make it flex???
UKMyers is offline
Old 06-03-2009, 08:36 PM   #16 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
Man that is a cool mod! I might just have to be on the look out for that!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
THE ULTIMATE TOYOTA RESOURCE
'86 4Runner SR5 22R-E
4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear.
Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000
Current pics
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
Admit it, you like reading my posts. It reminds you of the days before your runner was the monster that it is now.
BigBluePile is offline
Old 06-03-2009, 08:39 PM   #17 (permalink)
Lama glama's Avatar
Do you know how I might find this guy? I searched but didn't find much.
__________________
Brian
Old 06-03-2009, 08:42 PM   #18 (permalink)
89silverpu's Avatar
Quote:
The 4.88's are soooo nice! When I was out drivin lightly to begin the break in process all I wanted to do was gun it haha I'm goin up to Eagle Lakes/Fordyce the weekend of the 27th/28th of June (possible two day trip, maybe a one day on sunday, we'll see) that I'd love for you to come! I'll give you more details as soon as I know!
Quote:
Yeah man, wait till you can score a deal on one or it's gunna be anywhere from 800 to a grand for just the third I got mine for like half that!
__________________
Tread Lightly
Mixchallenge.info
Old 06-03-2009, 08:46 PM   #19 (permalink)
Wow, that's definately a wishfull thinking project then! lol!!
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
Current pics
'06 4Runner Sport
Old 06-03-2009, 10:58 PM   #21 (permalink)
89silverpu's Avatar
Quote:
Originally Posted by iamsuperbleeder View Post
now I want to do this...
maybe I need to finish my motor rebuild first
good job man!
haha I tell you what, when/if my motor ever needs a rebuild, you help me do that and I'll help ya with the locker retrofit
__________________
Tread Lightly
Mixchallenge.info
Old 06-04-2009, 09:09 AM   #22 (permalink)
89silverpu's Avatar
I just ordered a Marlin e-locker motor guard for it and I don't think I'll get the chance to hook up the wiring harness today, but hopefully soon!
Oh and one question, do you have to take the third out of the axle to weld on diff armor like this?
It'd be nice to not have to take everything apart lol and I should've though about it before I put it all together
__________________
Tread Lightly
Mixchallenge.info
Old 06-04-2009, 07:39 PM   #23 (permalink)
89silverpu's Avatar
I ended up gettin the switch in the dash, but didn't get the wires hooked up yet. I'll let the pictures do the talking...
Also, can anyone answer this question for me???
__________________
Tread Lightly
Mixchallenge.info
Old 06-04-2009, 08:15 PM   #24 (permalink)
I think you could if you do it really really slowly. As in weld then let it cool an hour and have about five of those rotations and evenly divide the welding up between those times.
__________________
"I love my 4Runner. Everyone else in my condo hates it! I guess it looks bad next to there brand new 20 or 30 thousand dollar cars that will die before my $600 Yota does, and probably before they're even done paying their cars off!" -Steveycapri
Whips: '92 Xtra Cab Dlx V6, '94 Dlx I4 5spd. Camry.
98% of the teenage population will try, does, or has tried smoking pot. If you're one of the 2% who hasn't, copy and paste this into your sig.
NOTE: To find the 2%...I'm the other 98%.
Mic09dcsm is offline
Old 06-04-2009, 08:32 PM   #25 (permalink)
iamsuperbleeder's Avatar
Send a message via MSN to iamsuperbleeder Send a message via Yahoo to iamsuperbleeder
I'm down man!
iamsuperbleeder is online now
Tags
cruiser, elocker, guard, land, retrofit
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
e-Locker retrofit on 3rd Gen Ritzy4Runner 95.5-2004 Tacomas & 96-2002 4Runners 31 12-09-2008 09:49 PM
E-locker Retrofit Albuquerque Jim The Fab Shop 7 02-24-2006 10:33 AM
E-Locker Retrofit xstickfightx Offroad Tech 1 10-28-2005 10:18 AM
e-locker retrofit write up not working? chuckd 95.5-2004 Tacomas & 96-2002 4Runners 2 07-18-2004 12:04 PM
retrofit locker wtmtnterror 95.5-2004 Tacomas & 96-2002 4Runners 1 04-07-2004 07:37 PM
2009 InternetBrands, Inc.
