88 toyota 22re , no power?
Old 02-25-2014, 04:27 PM
Tommahark's Avatar
Question 88 toyota 22re , no power?
Truck will not come on, no lights no sounds. Battery , starter and alt fine. What would be the most likely cause of this?
Old 02-28-2014, 07:32 AM
Jbowls's Avatar
Sounds like a wireing nightmare? I would check any ground wires then trace the hot wires. Checked all the fuses?
Old 02-28-2014, 08:33 AM
masterchiefhasayota's Avatar
Check efi fuse, maybe even test the starter relay. see if you can pull a code on it. Test the circuit opening relay. If that doesn't function, the gas pump wont turn on giving the engine the gas it needs to start.
Old 02-28-2014, 08:34 AM
Romans117's Avatar
Main fuse. Other fuse and the other fuse
DacodaYota
09-02-2015 02:13 PM
Sandman
07-23-2015 08:15 PM
renorunnerguy
3.4 Swaps
06-28-2015 09:18 AM
toy89yota
06-24-2015 01:18 PM
nyk08trx
06-18-2015 09:01 PM
Quick Reply: 88 toyota 22re , no power?
