88 4runner rear bumper mounts
Old 04-02-2011, 10:10 AM
brock77's Avatar
anyone know what bolt are used to attatch the mounts to the frame...and the bumper to the mounts....(Actually im missing all the nuts and bolts for this job)....im installing stock bumper and mounts......searched but cant find nothing.....or somewere on line that gives you the part number
Old 04-02-2011, 11:18 AM
corax's Avatar
on mine, the stock bumper attached to the body, not the frame. IIRC it used (4) bolts vertically that all snapped off when trying to remove them
Old 04-02-2011, 11:22 AM
brock77's Avatar
yes sorry the body......do you know what size these bolts are
Old 04-02-2011, 12:08 PM
4Crawler's Avatar
Yep, likely M12-1.25 if there are existing threads. If not, any 12mm bolt will work or 1/2" if you can't find 12mm. At least that is the size on the Tacoma rear bumpers. I never had an OEM bumper on my '85, but use 1/2" bolts to mount my rear bumper.
Old 04-02-2011, 12:20 PM
brock77's Avatar
right on thanks 4crawler....
Old 04-02-2011, 02:35 PM
brock77's Avatar
nope thats not the size......2 trips to lordco hahahahah....
Old 04-02-2011, 04:14 PM
corax's Avatar
12mm wrench = 8mm bolt if I remember correctly. I though a 12mm bolt was a bit big for a bumper so flimsily attached to sheet metal . . .
Old 04-02-2011, 05:17 PM
brock77's Avatar
ahhhh $h!t...ya ok....my bad.....thought you meant a 12mm bolt.....i pick up an 8mm bolt seemed to be the right one....but the thread wasnt right at least on the one i picked up...the part number is 91655-40820...but cant find the specs for the bolt...can any one else
Old 04-04-2011, 03:45 AM
offset442's Avatar
do you have a bucket of trail mix bolts? find one that fits then go buy more just like it.................and next time you have extra bolts left over save them, LOL
Old 04-04-2011, 05:52 AM
rattlewagon's Avatar
Old 04-04-2011, 09:03 AM
brock77's Avatar
the bolts are 8mmx1.25x20mm....ummm the runner never had a bumper or brackets on it when i bought it...bought the bumper used but the p.o didn"t have the bolts
Old 04-04-2011, 11:55 AM
XtraSlow_XtraCab's Avatar
You'll find that the majority of the machine bolts Toyota used were:
a) Undersized heads (a Toyota bolt with a 12mm head has a 14mm head at your hardware store)
b) Toyota used semi-fine to fine, never coarse.
stagger_lee
03-29-2016 06:27 PM
Outsane
06-24-2015 05:52 PM
dirtrider0129
10
06-24-2015 12:24 PM
westbound
06-07-2002 03:30 PM
Quick Reply: 88 4runner rear bumper mounts
