88 1st gen intermittant miss.
Old 09-13-2007, 11:03 PM
thorgod58's Avatar
Hola!
my 88 first gen, 3.0 auto, just started an intermittent miss today. What could be causing this? it will run smooth for a while, then start missing, then smooth...
Any ideas would be much appreciated.
thanks in advance,
Thor Taggart
Chandler, AZ
Old 09-14-2007, 12:48 AM
Jay351's Avatar
when was the last tune done on the truck?
I would start with that:
New spark plugs, cap and rotor and possibly fresh oil.
Check your airfilter aswell.
How old is your fuel filter?
Old 09-14-2007, 12:29 PM
4runnerx3's Avatar
Spray some carb cleaner on each injector to make sure none of the seals are bad, that's where I would start. If it revs up you found the problem.
Old 09-14-2007, 06:41 PM
thorgod58's Avatar
I did a full tune, turned out to be a bad spark plug wire, grounding on the block. With new cap and rotor, wires, etc, I don't know but it seems like it's running better than it has since I bought it...
Old 09-14-2007, 07:02 PM
Jay351's Avatar
good job
MaK92-4RnR
10-28-2015 02:45 PM
runnermedic
13
09-21-2015 05:20 PM
icentropy
09-10-2015 05:03 AM
larrys93pickup
09-06-2015 06:37 AM
Badfish740
09-04-2015 04:21 AM
Quick Reply: 88 1st gen intermittant miss.
