87 4runner' Rear wheel leaking gear oil
inner ... or housing seal .
have a good look at the bearing ... this is usually the culprit . The seals dont usually " go " with out a reason ..
another culprit , may be the diff breather .. make sure top is free .
Yea, it's possible that your have a clogged diff breather, but if oilis only comming out of one side then it's most likely a seal. I had that happen to my driver side years ago and it was the inner seal that failed. Guess it's not bad to have it go after 300k miles.
Inner seal is the oil seal the outer seal is a dust seal and water seal to keep the bearing dry. The bearing is permanently lubricated. If you leaked gear oil into it it will need to be replaced. If you don't replace it now you will be replacing it soon because the gear oil will have washed the grease out of it. :pat:
voiddweller
19
May 2, 2016 09:10 PM
cchinny
Jun 25, 2015 08:11 PM
WI Girl
Jun 25, 2015 03:45 AM
Mr.Black
Jun 21, 2015 10:17 AM
newzingo
Jun 19, 2015 04:37 PM
