87 2wd Frame and 86 4wd Frame (rear only)
Old Oct 29, 2007 | 01:45 AM
ndg's Avatar
ndg
I have a 86 4wd: everything is good except for the rear frame
Found a deal on a parted out 87 2wd with a good frame (2 hours away).
Is the back section of a 87 2wd Frame the same as the 86 4wd Frame?
In other words, can the back of a 87 2wd frame be matched/welded properly to the 86 4wd front? Would any other rear mounting modifications be needed?
Thanks in advance for any information on these frames!
Old Oct 29, 2007 | 04:23 AM
881stGenRunner's Avatar
the 4wd frames are fully boxed, i think the 2wd frames are C Channel.
Old Oct 29, 2007 | 05:00 AM
ndg's Avatar
ndg
My only reference to the 2wd frame is a photo in a Haynes manual, page 10A-2. It shows a 88 2WD and the frame from below center, it appears boxed (at least on the insides). All other mounting points appear similar to that of the 4wd.
Old Oct 29, 2007 | 05:05 AM
hmm, i may be wrong, ill let someone who knows more about this chime in.
smthwsn357
May 1, 2024 07:28 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
TokyoD23
Jul 12, 2015 06:01 AM
87turboPA
Jul 9, 2015 05:58 AM
