86 pickup problem
86 pickup problem
I went to start my truck yesterday and their was nothing. I just drove the truck like 30 mins ago. The battery is good cause my headlights, off road lights still work. I think its coming from my ignition switch. I have an 89 runner to and the wires are the came color but 2 more have power on my runner than my pickup. Can any one tell me where the black with red stripe wire and black with yellow wries go? Is their a resistor that went bad or some thing? All fuses are good.
from what I can tell with the diagrams I have,
black with red stripe comes directly from the battery and has a (looks like green insulated) fusible link in it near the battery and goes to the ignition switch
black with yellow stripe goes from the switch to the condensor (near the coil) and to the 15A engine fuse and to the 7.5A gauge fuse, the 15A turn signal fuse, and 20A wiper fuse.
Sorry you don't think I could help. Given it took me 5 minutes to locate the diagrams and 2 minutes to type my response, you could've done the same and saved yourself nearly 9 hours of waiting.
Good luck.
Good luck.
easy fix!!!!!!
exactly the same thing was wrong with my truck last week. i had headlights and
hazards but no dash lights, stereo, and (most importantly) not even a sound from the starter when i tried to start the truck. i replaced the ignition condenser and vvvvvwala. i got one from a salvage yard for 1 dollar and
installed it in less than 5 minutes. hope this helps (if you havent already figured it out already).
Jnkml
07-06-2015 01:20 PM
