86 idle issue
Old 06-22-2013, 07:42 PM
yotaboy423's Avatar
86 idle issue
I just bought an 86 4x4, 22r, and its got a couple problems, the biggest one I need to deal with is the idle issue, when i start it up when its cold it works fine, but.once it warms up a little it acts like the choke flips back on, isles.real rough and eventually bogs out, mind you it doesn't do it all the time just whenever it wants to,
I am also looking at replacing the carb any good ideas?
Thanks
Old 06-22-2013, 08:02 PM
toyotaman2000's Avatar
friend of mine had symptoms similar to this and it ended up being a really bad vacuum leak. Not sure if that's going on with yours but might be worth checking out.
Old 06-22-2013, 08:13 PM
Toyota~Boy's Avatar
Thanks
Do not go with Weber. There terrible. I have had 3 different ones all be a 32/36 and I have had no luck at all. My factory Aisin is the best carb I've ever used on my 22r.
I had a 350 Holley a few years back on another 22r and I really enjoyed it as well. It came in really good and produced great performance.
Old 06-24-2013, 07:42 PM
yotaboy423's Avatar
Is there a way to check the carve to see if the choke is flipping back on, and if was a vacume wouldnt it run like crap all the time?
Old 06-24-2013, 07:44 PM
yotaboy423's Avatar
This is the carb I'm looking at putting on to replace the old one, ideas?
http://www.lowrangeoffroad.com/index...arburetor.html
Sleaker
08-26-2020 06:03 AM
montanatruck
02-26-2017 07:07 AM
Alex Bessinger
08-31-2015 09:17 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
kyletbert
07-17-2015 11:39 AM
Quick Reply: 86 idle issue
