| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
7.5 to 8 inch swap
#2 (permalink) |
First off you mean 8"
Yes its possible but your going to have two different lug patterns if you do this. Front will stay 5 and the rear would be 6. Other than that you should be able to just swap it right in and even bolt it to the exact same spot and be fine
__________________
94' toyota 4runner (Many a change!) purchased bone stock, NOW... SAS, 39" Iroks, Rear Leafswap, 5.29's , Air locked front, Welded rear, Chevy 4.3L V6, 5spd swap, dual T/C's MC10R10, flatbelly with custom skids, sliders, Chopped, Bobbed and so much more. Might as well start reading this if ya want know more |
#3 (permalink) |
correct me if im wrong but it sounds like he is going to put a ford 9" in his project and then put the 8" out of his project truck into his 2wd dd truck.
if you did do this like stated above you would have 2 different lug patterns. thats all i can help with.
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust 120amp Mr. Alternator rear lockrite, optima yellow top xrc8 winch & AOR bumper coming soon my bikes: 1980 Honda CX500-1997 honda cbr F3 |
#4 (permalink) |
Yeah, the project is getting a 9 inch. The 8" donor truck is a 2wd, so 5 lug. From what I have researched all V6 trucks have an 8 inch.
What I am concerned about is the 3rd member width. |
#5 (permalink) |
Some info from Pirate:
-2wd v6 & turbo & 1 ton models have a 8" diffs, All other 2wd's have 7 1/2" diff. -7 1/2" diffs use 27 spline axles. -7 1/2" diffs are approximatly 8 5/8" from mounting surface of the diff to the mounting surface of the driveshaft flange. -8" diffs are 30 spline axles. -8" diffs are approximatly 9 3/8" from mounting surface of the diff to the mounting surface of the driveshaft flange. |
#6 (permalink) |
So my rear end would be pushed back 3/4 of an inch if I were to just bolt in the 8"
from what I understand |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3 inch suspension 3 inch body lift pics anyone? | BMWToyotaMan | 95.5-2004 Tacomas & 96-2002 4Runners | 33 | 02-14-2009 02:14 PM |
| 1997 TOYOTA 4 RUNNER ALUMINUM 16 inch WHEELS WITH 31 INCH ALL TERRAINS | BOSTON4RUNNER | The Classifieds GraveYard | 1 | 04-11-2008 12:27 PM |
| 3 inch suspension and a 1-2 inch body lift questions | BMWToyotaMan | 95.5-2004 Tacomas & 96-2002 4Runners | 17 | 03-12-2007 07:06 AM |
| FOR SALE! 63 inch chevy swap everything you need! | utah | The Classifieds GraveYard | 6 | 05-23-2006 06:53 AM |
