4x4 issues - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-26-2008, 04:40 PM   #1 (permalink)
4x4 issues
Alright... it's an IFS '87 and my 4x4 is not working.
front hubs locked, in 4x4 only the rear wheels are going.
I don't think my cv's are broken, but i have one front hub that is VERY tight and i have to lock it in with a screwdriver or something... as in its too tight to turn by hand.
Would that be enough to cause my problem?
TheUglyDuckling is offline
Old 08-26-2008, 04:56 PM   #2 (permalink)
INFINITY's Avatar
if one of the springs in the hub has broken or popped off it could be stuck in the unlock position. just take the outer hub off and look at it. just mark it with a marker then take the 10mm bolts out with the hub set to free.
follow the instructions http://personal.utulsa.edu/~nathan-buchanan/93fsm/
__________________
TRAIL GEAR's CUSTOMER SERVICE IS TERRIBLE MORE LIKE A HEADACHE OR PAIN IN THE A$$ THAN A SERVICE!
-1980 toyota 4x4 - 235/85/16 bfg M/T tires, 03 tacoma wheels, onboard air, trd camshaft, weber 32/36 carb, 4.88 yukons, lockright in rear, etc
-94 xcab SAS, arb/lockright, 5.29s, 4" lift, etc...
Yota tech gallary- http://yotatech.com/gallery/showgall...ser=15173&sl=i
Harley
INFINITY is offline
Old 08-26-2008, 05:01 PM   #3 (permalink)
tc
tc's Avatar
Does the 4WD light come on?
__________________
Check out www.coTTORA.org to hook up with great Toyota 'wheelin' folks!
Current - 93 4Runner: 3VZ 33"x10.50" no lift ARB F/R
96 Impala SS: My own personal cop car
Previous - 89 2WD Pickup 22R, Fabtech "Ivan Dan" lift, 31x10.50, IASCA World Finals 4th Place
Stop with the mods and get on the trail!
Pix at www.4wheelingoh.shutterfly.com/action
tc is offline
Old 08-27-2008, 02:53 PM   #4 (permalink)
4wd light does come on and it will go into 2 low and all that. i'm kind of leaning towards the hub thing... my front brakes were done about 2 months ago also. i'll take a peek at the spring today.
thanks for the link btw
Old 08-27-2008, 03:45 PM   #5 (permalink)
Jay351's Avatar
Send a message via MSN to Jay351
I bet the hubs are not put together correctly. Remove the cover and take a peek. They are a little tought to understand the first time (mostly the spring and prawl setup) but once you have done it once, its darn easy.
Here is the best picture by pictures writeup of rebuilding aisins that I have found. With it, the newest of noobs can rebuild these things.
http://forum.ih8mud.com/79-95-toyota...b-rebuild.html
I bet if you jacked up the back of your truck, locked the hubs and put it in 4wd. You will be able to see the cv joint going to that "tough" hub spinning. It will be the easiest axle to spin so all the power in the front will be sent there.
__________________
91 Pickup - xcab - 5sp - 3.0 - SR5 - 4x4 - 233,000kms |2.25" catback w/ magnaflow cat + glasspack | Weasy2k cams | Aisin manual hubs | Diff breather mod| Marlin HD clutch |3" BL | es3000's |2" AAL |1.5" bj spacers | ISR | Alpine headunit | 4" Infinity fronts/5" rears | 4.88's |Rear lockright | 33x12.50" BFG M/T on 15x8" steelies |Hella 500's |4" reverse lights| Grant GT |Downey idler arm brace|hella E-codes| Marlin armor | %100 Amsoil synthetic
http://www.cardomain.com/ride/2572486
Jay351 is offline
Old 08-27-2008, 11:51 PM   #6 (permalink)
fixed! the hub was retarted... unbolted it and it sprung out all over the place. wasn't hard to understand at all...
brake cleaned it all and rubbed some thick grease on it. feels like new.
thanks fellas.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
1993 4x4 pickup steering issues snowboardstudent 86-95 Trucks & 4Runners 6 08-07-2008 09:48 PM
96 4Runner 4x4 Issues ChadG 95.5-2004 Tacomas & 96-2002 4Runners 5 12-06-2006 09:35 AM
My 91 4runner, 4x4 issues AsahiMan 86-95 Trucks & 4Runners 13 08-07-2006 04:58 PM
82 Toyota 4x4 w/Tranny issues - what's the best solution? 82Yoda4x4 Maintenance & Repair Archives 4 08-28-2005 05:00 PM
Suspension issues: 91 4x4 Pickup ksurfer 95.5-2004 Tacomas & 96-2002 4Runners 1 08-28-2003 10:10 AM
2009 InternetBrands, Inc.
