4wd vacuum hose location question
Old 04-18-2007, 06:09 PM
silversup's Avatar
I was just changed the starter on on 95 4runner w ADD auto and went to use my 4wd yesterday and it didnt work. I did some research on here and started looking at the vacuum hoses.
I quickly saw 2 vacuum hoses disconnected in my wheelwheel area with the color rings outround them. Up top on the fender everything is connected. I have searched on the truck and the board/manual and just cant come up with where these connect.
Does anyone know where the lines go or what general area/object I should be looking for? Or have a pic?
Old 04-18-2007, 06:17 PM
Knuckles's Avatar
ill look them up for you
Old 04-18-2007, 06:24 PM
Knuckles's Avatar
Is that what your talking about, what i circled in red?
Old 04-18-2007, 07:00 PM
taikowaza's Avatar
nice diagram!
Hey mattbaby24- can you post the entire diagram (uncropped), with all the labels on it?
that is a sweet diagram for sure. thanks!
Old 04-18-2007, 07:02 PM
silversup's Avatar
The part circled I see under my hood. But there are more vacuum hoses in the area near my starter that need to go somewhere.
Old 04-18-2007, 07:45 PM
Knuckles's Avatar
i have two diagrams for that model 4runner. do you want both? do you need any other diagrams? ill be more than happy to post them for you.
Old 04-18-2007, 08:09 PM
Knuckles's Avatar
Iam having trouble finding anything near the starter. ill keep looking.
the only vacuum and vapor hose diagrams i could find.
Old 04-18-2007, 08:41 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Are the lines at your actuator connected? Might follow them back up to where lead.
Old 04-19-2007, 05:26 AM
silversup's Avatar
I am going to do an in depth look this weekend. Pull off the wheel and skid plate to find where these lines are going. Thank you to everyone who has posted. Especially that vacuum diagram.
Old 04-19-2007, 08:07 AM
Kutter's Avatar
There is actually a vacuum reservior located forward of the wheel in the passenger side that has lines to it. The line enter the fender well near the ADD VSV valve and goes forward to the reservior from there. Diagram below is location of ADD system components.
Old 04-19-2007, 08:23 AM
mt_goat's Avatar
Of course the lines ultimately end up at the ADD actuator to the side of the front diff. This may help:
http://www.4x4wire.com/toyota/tech/add/
Old 04-19-2007, 10:39 AM
silversup's Avatar
I saw that site. It really doesnt have clear pics of where the lines go. But guess what. The new pics I take after I find it...will..
Old 04-19-2007, 11:13 AM
mt_goat's Avatar
You mean where they go at the ADD actuator or intake manifold or everywhere in between or all of the above?
Old 04-19-2007, 11:33 AM
mt_goat's Avatar
Ok here's where they were on my truck before I defeated the ADD actuator. They are capped off now in this pic.
Old 04-19-2007, 02:12 PM
Kutter's Avatar
I just reread your original post. I bet you answered your own question. You said you found them in the wheel well. The only ADD component in the wheel well is the ADD canister located fwd. See the pic I posted. This canister has two nipples for two vacuum hoses. PUt them on if it works backwards then just swap them to the other nipple.
Old 04-25-2007, 06:58 PM
silversup's Avatar
Conquered the small problem. Lines went to the actuator. Took some pics. Didnt have my digi cam but i took some with my cam phone here they go. Blue hose on left, red on the right:
oldirtydirt
02-23-2020 09:30 AM
adammtb
07-27-2015 11:57 AM
TokyoD23
07-12-2015 06:01 AM
Coreyr384
07-10-2015 11:13 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: 4wd vacuum hose location question
