4runner jerks when headlights are turned on
Old 07-06-2007, 02:05 AM
TORTIS's Avatar
HI all,
When I am driving and I turn the headlights on, it,s like dumping the clutch when you push start a truck, like a jolt, just for a split second, then everything is fine . When the headlights are on, and I roll down the rear window, it jerks till I let go of the switch. When the headlights are off, and I roll down the window , no problem. Any ideas? Thanks. robert
Old 07-06-2007, 07:35 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Sounds like you have a bad ground and it's affecting the EFI delivery. Check your battery grounds to the body and the block. Look for corrosion or loose wires anywhere at all in your electrical system...even at the ECM (pass. side kick panel) and fuse boxes (driver's side kick panel and under the hood). Have you been blowing fuses, lately?
Old 07-06-2007, 11:16 AM
TORTIS's Avatar
Nope. No blown fuses. I'll check all the grounds. I wonder if this might be tied to my running rough problem. thanks. robert
Old 07-06-2007, 11:31 AM
Yota82's Avatar
I had the same problem on my 86 22RE. It was a power distribution problem. There is a wire coming off of the battery that goes into the underhood fuse box on the passenger side. When the headlights were on that wire would get really hot. I used a new thicker guage wire and it has been fine ever since.
Old 07-06-2007, 11:33 AM
Corbit's Avatar
check the alternator
Old 07-06-2007, 12:48 PM
surf4runner's Avatar
there is a writeup (somewhere) here for this exact issue.
Old 07-06-2007, 02:25 PM
95RunnerSR5's Avatar
i had this problem before and it turned out to be a bad connection on the negative side terminal on the battery
icentropy
09-16-2020 02:47 PM
MTLroadierunner
07-15-2015 12:58 PM
Kalihi,HI
07-09-2015 04:29 PM
musashi86
California SoCal
07-07-2015 03:31 AM
karbin
07-05-2015 11:37 PM
Quick Reply: 4runner jerks when headlights are turned on
