4" Suspension 3" Body lift, what size tires
Old 02-13-2008, 12:15 PM
  #41
wcc_71's Avatar
if i got the 4 in BS would the tires stick out the fenders alot?
Old 02-13-2008, 12:50 PM
  #42
ovrrdrive's Avatar
I don't think you can run 4" BS with a bracket lift. There just isn't enough room between the top of the spindle and the tire.
And btw, 7" of lift is plenty for a 35x12.50 or even a 35x13.50 if you can find one. If you want a little more lift, and more flex, then add a bj spacer but it's completely unnecesarry.
Old 02-13-2008, 12:51 PM
  #43
ovrrdrive's Avatar
The larger the backspace, the less the tire sticks out. You have it backwards.
Old 02-13-2008, 12:56 PM
  #44
wcc_71's Avatar
ok well ill prob do the 3.75 backspacing
Old 02-13-2008, 02:07 PM
  #45
Vohaul's Avatar
Originally Posted by AxleIke
How would that help with tree stumps? You *may* be able to clear them with a SAS, but unlikely. You don't gain that much clearance, and lose clearance under the diff.
The treestumps (we are talking 2-6 inch stumps here...) would get caught between the lower control arms and the skidplate...or in and amongst that area..had to hilift myself off.....happened in snow where you couldnt see to avoid
with a SAS..it would of just glanced off..
But in the most part, I'm pretty impressed with the strength of the IFS with the drop bracket lift....seems pretty well protected up front as well
Cheers
Paul
Old 02-13-2008, 02:12 PM
  #46
Vohaul's Avatar
i think im gonna run a 35 13.50 but i aint sure what tire yet
oh and with a 35" x 13.5....with 3.75 backspacing..be aware, youll probably need some sort of fender flare.....depending on your local laws of course...
i have 35 x 12.5's and they stick out 2-4 inches....the bushwhackers cover them up nicely though....xept for the right rear which got ripped off in the trees....sigh..(another job to do....anyway, i wandered off topic..
cheers
Paul
Old 02-19-2008, 07:30 AM
  #47
tacoma728's Avatar
That sounds like a good plan. The IFS is strong. People ruined the name of IFS when they lift trucks so equipped and attempt to run 38-42" tires through mudpits and bouncing over unforgiving terrain. You will be fine with 33x12.50s, perhaps, maybe even 35s, but that's pushing it over the edge. People think just because they can fit 37s or 38s, they should. Not the case in IFS.
Old 02-22-2008, 07:57 AM
  #48
tacoma728's Avatar
The pro comp would be a good choice.
Old 02-22-2008, 08:35 AM
  #49
Greg_Canada's Avatar
superlift/BDS are nice ones.
my cuz has a 4-5" superlift and 3" bodylift and clears 37x12.5 SSR's.
It rubs the front mudflaps sometimes, nothing some trimming/relocation wouldnt fix.
Old 02-22-2008, 08:54 AM
  #50
tacoma728's Avatar
with major trimming you can fit any tire size you want. Why not utilize 60" agriculture tractor tires?
Old 02-22-2008, 09:23 AM
  #51
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Yotoder865
07-09-2015 07:51 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 4" Suspension 3" Body lift, what size tires
