3vze radiator pressure test ?'s
Old 02-12-2012, 11:35 AM
runs-on-4's Avatar
im looking into a truck with a 3vze. i plan on this being a project truck. im heading over to do a compression test and another test im not sure the name of though but basically you hook a pump up to the radiator cap and pump it up and see if it holds pressure. which would test for leaks in the coolent system im looking for head gasket problems mostly
anyone done this before and know a good psi to test it at?
i was messing around with it on my dads hemi car and it went to about 13psi, then coolent came out of the overflow tube
Old 02-12-2012, 04:44 PM
MudHippy's Avatar
The FSM says 17.1 psi.
http://personal.utulsa.edu/~nathan-b...11radiator.pdf
Old 02-13-2012, 06:52 PM
runs-on-4's Avatar
thanks but before i got to the test i found some serious rust in the frame rails... the guy never mentioned that and said he never saw it aha
the1998sr5
15
07-14-2020 08:35 PM
itzmywife's
07-25-2015 04:55 PM
the1998sr5
07-16-2015 06:20 AM
88yodabasket
07-13-2015 01:32 PM
horunner1x
07-10-2015 06:33 AM
Quick Reply: 3vze radiator pressure test ?'s
