3VZE loosing coolant
Well, just did a compression test. My motor has 250kms (155miles) and it came out great.
cyl 1 - 183psi
cyl 2 - 178psi
cyl 3 - 182psi
cyl 4 - 172psi
cyl 5 - 179psi
cyl 6 - 185psi
as you can see those are excellent numbers, I think ive determined its not my head gasket, what do you guys think?
cyl 1 - 183psi
cyl 2 - 178psi
cyl 3 - 182psi
cyl 4 - 172psi
cyl 5 - 179psi
cyl 6 - 185psi
If that is the case then next question is how is the water getting in there. HG is the obvious one.....also, a pinhole in the aluminum intake could cause it. I would think a pinhole would cause all 6 cylinders to be clean.
#25
Yay fun! Whats your plan hg's or 3.4? I thought about a 3.4 when mine went but 3.4's seem to be hard to find in B.C. though i did see yesterday on B.C. 4x4 somebody selling a full 3.4 swap but i never looked into it so not sure what he actually has. Doing HG's isnt really that hard either. I think i got my hg's and gasket set for like 200 bucks or somthing? Then 6 cans of brake clean and many differnt oils later i had no leaks!
Blamalam
03-12-2022 07:34 AM
JaredL
03-28-2016 09:08 PM
TJWilly
07-31-2015 02:05 PM
