3VZE code 24 Help!
Old 03-02-2008, 04:36 PM
reehrlich's Avatar
3VZE code 24 Help!
91 3vz-e recently gave the code 24 so i replaced the air flow sensor (no engine light ever came on, just noticed engine losing power at ~3200 rpm).
i disconnected the battery to clear the code but the problem persists and it is flashing the "normal" code.
how long does it take to create a new code? i was sure the engine operating temp was hot enough.
could this be a fuel pressure problem? tps sensor? ect sensor? o2?
plugs are new but wires haven't been changed in about 3 years.
help!
Old 03-03-2008, 09:51 AM
reehrlich's Avatar
nobody? i can deal with searching for a sensor, i just hope someone will tell me the tranny isn't out or something.
Old 03-03-2008, 09:54 AM
WSUWESTON's Avatar
You might try posting it in the 2nd gen section to get more looks? Good luck
Old 03-03-2008, 10:24 AM
zlathim's Avatar
A less ambiguous thread title may help as well. Something like "3vz-e code 24" would probably get more response. Just an idea, take it for what it's worth...
Old 03-03-2008, 11:48 AM
aviator's Avatar
I'm not very familiar with this code (since I've never had it) but I re-titled and moved the thread so hopefully someone will see it and chime in with some useful advice lol.
Old 03-03-2008, 12:26 PM
reehrlich's Avatar
ok, so just finished new plugs and wires and the problem is still there. i noticed a small crack on the air tube lip that connects to the throttle body.
could this small crack cause this?
and it still wont give a code after a 10 minute warm up. any advice on troubleshooting without codes?
LotOMiles
09-14-2015 11:45 PM
EatChipsNow
09-09-2015 01:25 AM
FJtoyman
09-08-2015 04:47 AM
PureTacoma_Tundra
Vendor Advertising
09-06-2015 06:38 AM
moparbay
09-03-2015 12:48 PM
Quick Reply: 3VZE code 24 Help!
