3VZE Camshaft Position
Old 01-23-2007, 02:50 PM
Ebin's Avatar
I'm putting everything back together after an HG replacement. I think I know the answer but I just need confirmation. After re-installing the camshafts, will the Dowel Pin hole on the passenger side camshaft be offset to the left? Which means when I install the timing belt some of the valves on the passenger side will be open?
Old 01-23-2007, 07:55 PM
milowilli's Avatar
just make sure that both sprockets line up with the notch on the back cover and the crank pulley is on TDC...Recheck when tensioner is released..both notches must line up exactly.
Old 01-23-2007, 08:00 PM
AuburnRunner's Avatar
... when you are placing the camshaft back in the bearing journals yes, the pin will be offset to the left a little bit. But once you torque down all of the bearing caps center the pin up with the marks like milowilli said.
Old 01-23-2007, 09:21 PM
Ebin's Avatar
Now I am confused, am I supposed to turn the camshaft to center when I torque the journals down or do I just turn the camshaft to center when I put the belt on? Because if I turn the cam to center before I torque the journals down, couldn't this damage the cam?
Old 01-23-2007, 09:22 PM
Ebin's Avatar
Please Help!!!
Old 01-23-2007, 09:25 PM
ChickenLover's Avatar
Just set the cam in there and torque the bearing caps down. It does not matter what position the cams are in. The cam sprocket only bolts on one way. You'll line it all up later, when you put the belt on. Positioning during initial cam installation does not matter.
Old 01-23-2007, 09:52 PM
Ebin's Avatar
Thanx Chickenlover, that's what I thought but I just wanted to hear it from someone else.
Old 01-24-2007, 04:17 AM
Th3duke's Avatar
bump -- man I love this board!
MadMax48
03-03-2020 10:33 AM
Hugh_Mann
09-16-2015 03:59 AM
Quick Reply: 3VZE Camshaft Position
