3vze 3.0 problem
Old 06-08-2011, 04:27 PM
timmietate's Avatar
3vze 3.0 problem
i have a 1990 toyota pickup with the 3.0 and my engine started running rough its a new engine and i got code 31
(mass air flow or vacuum swith) and 52(knock senor). Well ive put two new mass air flow sensors on and 3 sets of vacuum switches and it hasnt changed anything, but the maf where reman. the first one i put on lasted about a week before it started messing up again and the second just didnt do anything at all. any suggestions?
Old 06-09-2011, 03:38 AM
TNRabbit's Avatar
If you put a MAF on it, it won't work because the 90s use a VAFM. Have you checked the wiring leading to the VAFM & Knock Sensor? The knock sensor is a PITA, located under the intake. Probably just the pigtail that runs to it is bad. There are TONS of threads on here about both issues.
tobylab
01-18-2016 07:06 PM
Alex Bessinger
08-31-2015 09:17 AM
tobylab
07-12-2015 12:53 PM
smiley52
07-11-2015 05:16 AM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 3vze 3.0 problem
