3rd member removal help
Old 05-30-2015, 12:43 PM
abalagtas's Avatar
I have everything off....axles, drive shaft, all bolts around 3rd.....seems like it should come loose with some wacks of a BFH....no go...tried to pry with a big screw drivers...doesn't budge....tried a few wacks with a chisel....nothing.
should I just keep trying with the chisel?
Old 05-30-2015, 12:53 PM
millball's Avatar
More power!!
Don't bugger up the sealing flanges trying to wedge it loose.
Old 05-30-2015, 01:45 PM
ET
ET's Avatar
put a jack underneath the pinion side and jack up on it slowly. that's how i got mine off. worked like a dream
Old 05-30-2015, 02:32 PM
abalagtas's Avatar
darn ET...wish I had read ur post earlier....I basically wacked it a BFH and wiggled it out.
On initial inspection, the ring looked good...then I put a light down into the pinion and it was missing a few teeth...ugh.
jerusry
10-19-2015 05:28 PM
BeMiceElf
10-10-2015 09:40 PM
58rennur4
08-04-2015 08:49 AM
Quick Reply: 3rd member removal help
