37 inch tires 2 much for a 22re with 5.29's
Old 02-29-2008, 09:01 PM
WCorbett's Avatar
take out the BL. Its pointless.
Old 03-01-2008, 03:45 AM
ovrrdrive's Avatar
Originally Posted by tc
BS - but closer than most get it. Both 5.29 and 5.71 have 7 tooth pinions. So, technically, the 5.29 might be infinitesimally stronger, for all real world truth, they are the same. If you want a significant step up in strength, you have to go to 4.88.
That's BS too. I'm a metallurgist. AT BEST, cryo treating will make up for a bad heat treatment. Realistically, it does little but add cost.
In my experience, you need to keep these motors (both the 22RE and 3VZE) over 3000 to be in the powerband and have a chance of holding the gear into the wind or up any kind of rise.
Zuk sure seems to be a believer in cryo...
I know that's not the end all opinion on it, but I sure do trust his judgement.
Old 03-01-2008, 08:08 AM
tc
tc's Avatar
Maybe I need to rephrase...
IF the heat treatment is done properly, cryo won't make a significant difference. ALL gears are heat treated in large batches, with a heat treatment defined for the vast majority of users.
Zuk advocates an individual heat treatment of the gears (or at worst a small batch) with a special cycle designed for how we use gears. I agree that this makes a difference. I'm saying it's that whole operation of individual heat treatment with the special quench and temper (in most cases multiple temper) cycle, not the cryo part, that makes the difference.
Old 03-01-2008, 08:12 AM
ovrrdrive's Avatar
Gotcha...
Old 03-01-2008, 08:48 AM
  #25
SEAIRESCUE's Avatar
Wow, I would be worried about the 4 huge flywheels and the trucks, and my, ability to stop the thing at 60 MPH.
I think you are better off with an off-road ride and a DD. Fuel is approaching $4/gal and riding around in a jacked truck with it WFO all the time is going to eat your wallet dry.
My$0.02
Old 03-01-2008, 04:49 PM
  #26
ovrrdrive's Avatar
My gas mileage is virtually unchanged from the 4.10's and 32's to now. It's really a non-issue...
Old 03-03-2008, 08:00 AM
  #27
alpine4x4's Avatar
5.29's have 3 more teeth on the ring gear itself therefore the teeth are bigger=more strength. Not alot but definatly stronger than 5.71's. This is why most manufacturers do not reccomend 5.71's with toyota gears.
I wouldnt cryo a rear set either. Cryoing makes them more brittle and for DD duty it will have a higher chance of breakage. Cryoing the front will be ok butid leave the rear alone.
I agree with the powerband. On a 3vze youcan slip into the mid 2000's and be alright because of the slight amount of torque increase but around 3000 is optimal.
Old 03-03-2008, 08:54 AM
  #28
AxleIke's Avatar
In practice, MANY people have had ZERO issues with 5.71's, and ZUK has a nice article on it. Sums the differences up nicely. Not a lot of truth to the myth.
http://www.gearinstalls.com/410suck.htm
Old 03-03-2008, 09:35 AM
  #29
BigBoy60's Avatar
what kind of gas mileage are you getting now?
Old 03-03-2008, 10:01 AM
  #30
alpine4x4's Avatar
Stock to aftermarket.
As you increase the amount of teeth the size of the teeth decreases increasing chance of breakage. But then again if the 5.71 pinion contacts more teeth than the 5.29 strength is gained for the load applied is spread over more teeth.
I think a full in depth study is needed. Maybe take aftermarket gears ratios 4.10, 4.88, 5.29, 5.71 and measure sizes of teeth, pinion teeth sizes, amount of teeth on pinion and ring, and amount of tooth contact. That will give ALOT of info that might clear up a myth. There are alot of variables not explained in that link that can change strength but good none the less. Ya learn something new everyday!
Old 03-03-2008, 10:28 AM
  #31
tc
tc's Avatar
Glad to see you came to your senses.
The ring gear is a fixed size, so to fit more teeth, they have to be smaller. To fit the ring gear teeth, the pinion gear teeth have to be a similar size, so the number of teeth determine the size of the pinion essentially.
So, in other words, all the arguments you make for 5.29 being OK are MORE SO for 5.71's. In BOTH cases, you have 7 teeth on the pinion and setup is CRITICAL to ensure that you have the constant 3 teeth engagement that is required of ALL gear drive systems.
Old 03-03-2008, 11:22 AM
  #32
alpine4x4's Avatar
Haha yeah total brain fart on my part. I went a re-read that and realized where i made my mistakes.
Now i read somewhere i believe that the 5.71 has 6 pinion teeth while the 5.29 has 7?? Read it on marlin in a ring gear debate. Somehting about a different 5.71 ring gear being compared to a toy 5.71 or such.
Old 03-03-2008, 01:58 PM
  #33
ZUK
ZUK's Avatar
Ya Alpine, you read that from the factoid of 4x4pirate....571 has 7 teeth in real life and has about the same contact ratio(tooth contact).
Actually, when 571 gears are set up right they seem to handle 42" tires like Flexor is using now. Flexor is my local test case....the 571 gears are opening eyes at all the death defying waterfalls.
here is his rear 571 build and has been holding up almost 3 years now. Note that this is a 4 cylinder 3rd with 4 cylinder gears.
http://gearinstalls.com/flexor1a.htm
here's his front build and it describes all of what is in his rock-buggy also
http://gearinstalls.com/flexor1c.htm
It's all about the gear quality and the actual install
Old 03-03-2008, 02:42 PM
  #34
tc
tc's Avatar
Precision Gear says 7 teeth
http://www.precisiongear.com/toy8.htm
http://www.precisiongear.com/toy8v6.htm
http://www.precisiongear.com/toy712.htm
Old 03-03-2008, 03:24 PM
  #35
Hayes's Avatar
He also says that 5.71's are just as good, if not better, than 5.29's...
Old 06-24-2009, 06:55 PM
  #36
Can'tStopThe'Yota!'s Avatar
I have a 86 pickup 4x4. I have 5.29s , a five speed manual, and 37x13 boggers. its a little sluggish but not much worse than it was stock. im running a 22r and it turns the tires fine. but i wont lie that 5th gear is basically useless. it cant hold speed easily.
Old 06-24-2009, 07:27 PM
  #37
Tyler22re's Avatar
Dude 5.29's would be perfect. i run 37x12.50x15 ssr swampers with stock gears..
My trucks slow but it cruise's in 4th gear like at 65 mph so with 5.29's you should be golden..
Old 06-24-2009, 07:33 PM
  #38
yoder519's Avatar
holy old thread! dag on tyler you got 37s on stock gears!!!??? that takes some nads. i got 33x12.50s on stock gears and its not unbareable but pretty dern slow
Old 06-24-2009, 07:35 PM
  #39
Tyler22re's Avatar
Dude trust me it SUCKS.. thats why i wish the machine shop woudl hurry with my axles.. lol.. It takes ever bit of a mile to really get moving lmao.
Old 06-25-2009, 03:40 PM
  #40
KGRMINI's Avatar
My response to your arguments and gear strength is quality gears are only as good as the person putting them in. Its all about clearances and if its out of spec you will eat up any set of gears.
Flying91
45
04-11-2024 04:39 PM
coffey50
07-28-2015 10:55 AM
Michael oaks
07-27-2015 11:47 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: 37 inch tires 2 much for a 22re with 5.29's
