3.4 Vacuum line mystery
I just completed a head gasket job on my 3.4 engine and I seem to have a mystery vacuum line I cannot find where it goes. There are3 metal vacuum tubes sitting on top of the fuel injection. The thinner tube has a "T" on it and I found one end of it not hooked up to anything. For now I stuck a yellow cap on it. Can someone tell me when this goes??
Also on I side note when I hooked the wire harness to the TPS (throttle position sensor) I noticed a connector not connected to anything. It is so short nothing will reach it. Maybe its not used on my engine but was curious what it was for.
Regards,
Mike
[IMG][/IMG]
Regards,
Mike
[IMG][/IMG]
Mine heads to a check valve and then to the controls for the ADD diff/hubs VSV......original from the factory. On a swapped engine, hard to say...you should have a loose tube someplace.
absolutely .. and that looks like a factory " T " .. and possible explanation of it being blocked off , maybe the previous owner went with manual hubs ? IDK? .. I was just offering some more info for the fella ...
edit .. ohh I guess I didn't read enough .. you just did the head gasket ! sorry , I missed that .
so yeah , obviously it had to be hooked up to something
Tacoma1313
08-17-2015 05:44 PM
TokyoD23
07-12-2015 06:01 AM
