3.0td surf high rpm miss
Old 10-20-2014, 11:46 AM
stefan1's Avatar
Hi there sorry if i have done something wrong but im new here and to a hilux! I have a 3.0td surf 1996 and having a few teathing problems.... its a auto and if i put my foot down it cough and splutters. The other day it even cut out whilest going along. It also seems to be alot worse when going up a small hill.
Old 10-20-2014, 05:34 PM
oldblue's Avatar
could be a number of things. but if it bucks and jerks going up a slight incline hill under normal driving, that sounds like an ignition misfire. take a look at the plugs, wires, and cap/rotor. if you are unsure of the last tune up, wouldn't hurt to go ahead and replace all of those.
Old 10-20-2014, 06:08 PM
bigt's Avatar
i think he has a diesel...
i would check your fuel filter first off..
most ppl are here has gas toyotas
Old 10-21-2014, 12:29 AM
totally a bro
Staff
vital22re's Avatar
Possibly the injection pump. But start with the filter.
Old 10-21-2014, 10:04 AM
oldblue's Avatar
yeah i'd still check the cap/rotor and plugs and wires...............................
Old 10-21-2014, 10:52 AM
JasonYota's Avatar
Either your trying to be funny or don't know your way around a Diesel engine.
Make sure there isn't any water in the fuel, I second the others, start with the fuel filter
Old 10-21-2014, 12:13 PM
oldblue's Avatar
sarcasm is hard to express over the internet. i saw 3.0 and assumed gas engine.
fuel filter would be a cheap place to start, and its a maintenance item anyways. not sure how to test for a bad injection pump. i do know from farm tractors that injectors can clog over time and need to be rebuilt. i take those injectors to a diesel injection specialty shop and they can check the spray pattern and check for leaks, and they can rebuilt them as necessary
Old 10-21-2014, 12:17 PM
oldblue's Avatar
also, another common thing i see is dirt in the fuel lines from the pump to each injector. i'll remove each line one by one and blow them out with air. usually there is a constant miss when this happens though.
Sleaker
08-26-2020 06:03 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: 3.0td surf high rpm miss
