3.0 Valve adjustment - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-24-2007, 09:44 PM   #1 (permalink)
CoedNaked's Avatar
I know this topic has been covered pretty well in depth but....
I talked to a tech at the dealership and he said that when he has checked valve clearances on the 3.0's during rebuilds, he said they are never that far out of spec, so I asked him why the valves are so noisy? I can't recall exactly what he said as I'm not super familiar with engine internals, but he implied something about it could be the valve hitting the bucket or something like that (does that make sense? maybe I heard that wrong?).
So what I'd like to know - my truck is a little "ticky" which sounds like valves. I'm curious if I had valve adjustment done, would it quiet things down a little?
Make it run smoother, etc. ?
What I am thinking of doing is doing an oil analysis on my next oil change to get an idea of how the oil/engine is doing. I know I have a small valve cover leak which is where I'm probably losing oil, but I want to confirm that and make sure my seals aren't leaking too much fuel/blow by. If they are, I'll scrap the valve adjustment until a rebuild, if it is just the valve cover leak I'll look into getting a valve adjustment done when I have the timing belt done.
Thoughts?
__________________
1993 Xtra Cab Pickup | 4x4 | 3.0 - V6 | R150F | Silver-Grey | Amsoil 10w30 synthetic oil | Amsoil Synthetic Drivetrain fluids|
Borla Cat-back Exhaust | OME HD Leaf Springs | Bilstein HD Shocks | Downey Idler Arm Brace | Grey Husky Liners | SR5 Bucket Seat Swap | Color matched Canopy | Yakima racks | Line-X OTR | Michelin LTX A/T 31 x 10.5 x 15 | 323,600 KM's (202,250 miles) | Made in Japan - Vin starts with "J"| Fish on
CoedNaked is offline
Old 01-25-2007, 12:49 AM   #2 (permalink)
Just Learning's Avatar
some times if the exhaust manifold is not snug it will sound like valve noise??,but arnt those hydrualic lifters??? if not and you do get a valve adjustment and a valve was pertty out of spec this could be the noise and this should solve the noise problem
Just Learning is offline
Old 01-25-2007, 12:57 AM   #3 (permalink)
ChickenLover's Avatar
When I first got my runner, I was perplexed by the ticking noise it made. I had the valves checked. They were fine. Had an exhaust shop check for leaks. There were none.
The 3.0 is a fairly noisy engine to begin with. My problem turned out to be a worn-out steering shaft seal. A rubber seal that goes around the steering shaft where it pierces the firewall (inside of truck). Because of the lack of the seal, all that normal engine noise was coming right into the cab. Once I replaced it, I felt like I was driving a different truck. It was so much quieter. It made all the difference in the world.
This is a fairly common problem on these trucks. It is certainly worth having a look at.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 01-25-2007, 04:16 AM   #4 (permalink)
TNRabbit's Avatar
It's usually the INJECTORS that cause all the underhood ticking noise in most cases.
__________________
TNRabbit
Stock '94 DLX XtraCab 4x4 5 spd, Newly Rebuilt 3VZE, 17" 2006 Alloy Wheels, 228k miles, AISIN Hub Swap
3.0 Rebuild Thread: http://www.yotatech.com/f116/crap-he...-ghost-108156/
Quote:
Originally Posted by Junkers88 View Post
Like the good book says "you can give a man a Toyota and he will wheel for a year, you can teach a man Toyota and he will wheel for a lifetime."
yotatech 3:16
TNRabbit is offline
Old 01-25-2007, 07:46 AM   #5 (permalink)
at least on my engine, it's the injectors that are so noisy.
try reving the engine to at least 2500 rpm, then release the throttle. does the ticking go away for a brief second? if it does, then it's your injectors because this test triggers a fuel cut until the engine drops to below 1500 rpm
jht3 is offline
Old 01-29-2007, 08:43 PM   #6 (permalink)
That's a great tip! I'm going to try it.
-john
__________________
My Little Truck: White 1992 XCab 3.0L 4x4 Pickup w/ 6'6" Western Unimount snowplow
My Big Truck: White 2002 F350 7.3L PSD 4x4 Auto; Crew-Cab, Long Bed
JohnStra is offline
Tags
30, 3vze, adjustment, noise, ticky, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3.0 Valve adjustment CoedNaked 95.5-2004 Tacomas & 96-2002 4Runners 7 10-28-2009 06:38 AM
Valve adjustment on Rebuild Leprechan 86-95 Trucks & 4Runners 1 12-08-2006 07:33 PM
Valve Adjustment MMA_Alex 86-95 Trucks & 4Runners 10 06-30-2006 06:33 PM
3.0 Valve Adjustment dmatter 86-95 Trucks & 4Runners 9 03-14-2006 10:49 PM
valve adjustment yotarunner96 95.5-2004 Tacomas & 96-2002 4Runners 7 03-09-2006 08:22 PM
2009 InternetBrands, Inc.
