3.0 Torque versus Horsepower
This isn't related to displacement; it is dictated by the engine design and what rpm the torque and power peaks occur at.
For example, a stock '87-93 Ford 5.0 high output came with 225bhp and 300lb-ft. Peak power came in around 4800rpm. Build that same engine to make 450bhp at 6500 rpm and the power will be higher than torque with no change in displacement.
I did read your whole post. Now do me the favor of digesting mine.
If the power peak occurs at an RPM higher than 5252, then torque will be lower than power regardless of displacement.
Oh yes you can! Take a ride with me in my LS1 GTO and believe me, I will show you torque that you will feel! You will feel it so much so you'll pee your pants! 300ftlbs of tq at 2000rpm (to 6000rpm) with a peak of 365ft lbs is a beautiful thing! (oh yeah and 29mpg too! hehe!)
Any vehicle regardless of its make or type will accellerate the hardest at its torque peak. The "HP" section of the curve is merely a calculated number based off of the torque.
Originally Posted by CoedNaked View Post
I....Torque is something you can't really feel...
Matter of fact, TORQUE is the ONLY thing that you feel. You don't "feel" HP.
Fred
#25
As with anything regarding TQ and HP, they are directly related, absolutely, 100%. The formula has already been posted. Dyno's don't even measure HP. They measure torque and the HP is computed (using the already given formula).
You can't increase torque without increasing HP.
Those "smaller" bikes with the 4cyls, like the 600cc's produce all of their HP simply through RPM's.
Those engines really don't produce much power at all, but "work" because of their revs. Most of those 600's run around 12K RPM's.
Fred
Fred
#26
The two of them are linked. Torque is a measure of engine's ability to accelerate a rotation, or a twisting force it is only a force. Power is a measure of the engines ability to do work. But, let's imagine an engine even more gutless than my 3vze, one that produces so little torque that it cannot turn the flywheel, it produces some torque but not enough to spin the flywheel. So even though a force is being applied, no work is being done because no motion has occurred, this engine does not produce a measurable amount of power at the flywheel. So, again HP is calculated based on torque, as was said earlier, and if you look up the S.I. units of energy, work, and force in any physics text you can easily see how they relate. Go read a book and learn some .
I don't know if that helps.
Chris
Chris
#27
it seems to me that the 3.0 has a rather high torque peak.
doesnt 3400 seem a little high for a truck motor.
this motor seems to have a much better rev capability than say a ford 3.0
perhaps its the tranny on the ranger. the one i drove was more responsive.
side by side at half throttle the ranger blows the toyota away.
but at full throttle the toyota pulls better once its past 3400 or so and will eventually pull the ranger.
this is regarding 2wd automatic trucks.
150 hp at 4800
180 lb ft at 3400
150 hp at 4800
180 lb ft at 3400
#28
The late '90s Ford 3.0 has similar output characteristics; 150hp @ 5000rpm and 185lb-ft @ 3750. It's still a turd, though. The 4.0 blew it out of the water with more torque, more power, and the same fuel economy.
#29
Motorcycle engines are a diferent story. Racing depends largely on power to weight ratio. Motorcycles don't wiegh much, so they won't need much torque, but the more the better. As for Torque not being related to Displacement, and more related to RPM's, I'd really like to see your source on that. Maybe why does the Supercharged 2.2 liter Honda 4Cylender engine make 300HP@6800RPM, and 300ft-lb of torque at around 3450RPM?????
#30
What is "the" supercharged Honda you speak of and what blower type?
#33
#34
You really need to pay more for your rope.....
There is no way in hell that you got a 20% INCREASE in fuel mileage and a ton more power by simply removing the cat (which provides almost no restriction at all) and straightening out the exhaust.
If you did then something else was really pooched, such as a totally blocked cat, major crimped (bent) exhaust pipe or whatever.
Fred
Fred
129Creepin
08-05-2015 10:12 PM
