3.0 RPM too high?
Old 11-06-2012, 09:15 PM
DeathLK's Avatar
I got the truck in June and that's what got me into the Yota world even more. The tires came with the truck.
Old 11-06-2012, 10:37 PM
combatcarl's Avatar
Ah. Ya should look up on here how to figure your rear end ratios, it ain't hard, then look at your door sill plate, and see what it says for a ratio code.
'89 22RE 4x4 longbed DLX
Sent from my LG-P505 using YotaTech
Old 11-08-2012, 08:25 PM
DeathLK's Avatar
Thanks a lot man, I'm trying to get my knowledge on Yotas better. Do you know the difference the 3.4 V6 will do?
Old 11-08-2012, 08:33 PM
combatcarl's Avatar
Like 3.4 swap? It'll give you butt-ton more power, reliability, and waaaay more aftermarket support. If there isn't any current issues with your 3wheezy, I'd run it, saving for the 3.4, and swap when the motor poops out, or when you're all saved up.
Old 11-08-2012, 09:30 PM
  #25
ThatGuy1295's Avatar
Lots of people throw red flags at the tach on these trucks. It does seem odd cruising at 3,000rpms, but their designed to. Its not a 350 V8. Big difference. 3.0 is a good engine, and if you knew more about it you wouldnt complain about the high rpms. Just drive it. Believe it or not you get alot better mpgs's then any motor around that year thats cruising at 1800rpms @ 70mph. Especially in a 4,500lbs wind box.
Old 11-08-2012, 09:32 PM
  #26
DeathLK's Avatar
Is that what's in your rig? I've heard nothing but good review but its tough getting it here in California. It will cost me about 4 grand.
Old 11-08-2012, 09:38 PM
  #27
Read my previous post. I own both motors.
But swaping engines is not going to change your rpms.
And is only going to change mpgs by a 1-3 mpg amount if its done right.
Old 11-08-2012, 09:43 PM
  #28
I really wish my tires didnt have to spin so fast on the freeway.
And that was a joke, but seriously the high rpms are norm. Its part of the design, and these trucks outlast fords and chevs by 1 to 2 hundred thousand miles.
calderp
Engine Swaps
08-16-2016 05:15 PM
Alex Bessinger
08-31-2015 09:17 AM
calderp
07-27-2015 09:58 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: 3.0 RPM too high?
