2nd Generation 4Runner Rear ABS dash light
Old 04-19-2007, 06:21 PM
Frank Stokes's Avatar
If anyone needs to test their ABS rear differential sensor to see if it is bad, or if the sensor broke off in the rear differential port where it is attached, simply place a 1/2 watt resistor (within the range of 580 to 700 ohms), across the two wires attached to the sensor. Your Rear ABS dash light should now go off if the sensor is bad. This is a simply way to test to see if you need a new sensor.
Valvoman
06-28-2015 02:45 PM
cchinny
06-25-2015 08:11 PM
Taz22R
06-21-2015 04:44 PM
ShaunKris
06-17-2015 04:33 PM
Quick Reply: 2nd Generation 4Runner Rear ABS dash light
