22re wont start after bj spacers
Old 08-19-2007, 08:58 AM
red89yota's Avatar
Ok heres the problem I just did a ball joint spacer install on my 89 22re 4x4 5-speed and now it wont start it was running perect before I did the install. My fuel pump, tank and filter are only about 3 months old.
Old 08-19-2007, 09:09 AM
Bear80's Avatar
not related to your work. Better define "won't start." Will the starter turn the motor over but no fire OR no stater action.
Old 08-19-2007, 09:13 AM
sdstud212001's Avatar
Did you happen damage the starter while lifting it? Maybe the + wire came loose from the starter? If is a stick are you pressing the clutch all the way down?
Old 08-19-2007, 09:26 AM
RustBucket's Avatar
Did you forget to use the special balljoint grease that the FSM recommends? If you don't have the right grease, then buddy, your truck is HISTORY!
Old 08-19-2007, 11:21 AM
red89yota's Avatar
never mind it finally started it was just setting there spinning over guess something up with fuel pump.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
colinmil
07-06-2015 04:03 PM
karbin
07-05-2015 11:37 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22re wont start after bj spacers
