22RE valve train oil problems - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-07-2006, 02:10 PM   #1 (permalink)
InternetRoadkill's Avatar
Question 22RE valve train oil problems
I removed the rocker assembly from my 22RE today in an effort to replace what I thought was a defective rocker arm. As it turns out, all of the rockers are showing various degrees of distress. The shoes which ride on the cam are all showing heavy wear despite the fact that the engine only has 90 miles on it. The cam lobes are heavily worn as well to the point that the cam is no longer servicable.
My first guess is that this is the result of a severe lubrication failure. But I have good oil pressure and there is plenty of oil pooled on top of the head. This leads me to believe that the rocker shafts themselves are not getting oil for some reason.
The history of the engine is that it got a full rebuild including a new cylinder head, oil pump, rocker shaft, rockers, cam, and ARP head studs. The lobes were greased with the grease that came with the cam and GM's EOS was added to the oil as specified by the cam installation instructions. The cam was broken in per the instructions as well.
What looks like might be the problem is the clearance between the ARP head studs and bolt holes in the proline cylinder head. It looks like the 22RE passes oil along the side of the head bolts into the pillow blocks that support the rocker shafts. The ARP bolts fit rather slugly in these holes which leads me to believe that the studs are preventing the rocker assembly from getting full lubrication.
I know that ARP studs and the proline heads are a fairly common upgrade to the 22RE which is why I'm confused about why this happened. Any thoughts?
InternetRoadkill is offline
Tags
22re, oil, train, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Knock Sensor Code 12 could this be caused by valve train lifter noise being to loud slinkyeleven 86-95 Trucks & 4Runners 3 07-09-2007 07:59 AM
Valve guides or Oil rings going on 120k mi 22RE?! 91RN81 86-95 Trucks & 4Runners 4 12-21-2006 06:58 AM
? Valve Train Noise WatsonMD General Vehicle Related Topics (Non Year Related) 3 01-02-2006 06:54 PM
22RE Oil Filter Problems kryptik 95.5-2004 Tacomas & 96-2002 4Runners 10 07-26-2005 04:47 AM
2009 InternetBrands, Inc.
