YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-11-2008, 02:24 PM   #1 (permalink)
22RE Vacuum Lines
Were do the last three vaccuum hoses go in this picture? The bottom 2 i have no place for them to go. And i want to make sure the top is in the correct location. Once i get this right i am ready to fire up the motor.
Thanks!!
__________________
Dan Stewart
1952 CJ3a
1989 4Runner
DanStew is offline
Sponsored Links
To remove this ad, register today!
Old 05-11-2008, 02:36 PM   #2 (permalink)
94toy4x4fever's Avatar
Is this a cali emissions truck or fed emissions
__________________
94 toyota pickup. Work in progress!
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Want to do: SAS, Lift, 35" tires change gears, V6 swap
94toy4x4fever is offline
Old 05-11-2008, 02:39 PM   #3 (permalink)
Do you have a vaccum diagram under the hood of you truck? If not look in a chiltons hand book!
__________________
22re w/ RV cam
pacesetter header
K&N cold air
31" cooper stt's
Old 05-11-2008, 04:44 PM   #4 (permalink)
on my 95 22re the top one goes to the charcol canister i believe on the left hand firewall, the middle to one goes on the vacume plugner thing under the intake, and the bottom one goes to the vacume plunger thing at the end of the fuel rail. Hope this helps
killer305 is offline
Old 05-11-2008, 04:55 PM   #5 (permalink)
Thanks I found it in a manual. Turns out i connected something to the charcoal canister and it wasnt suppsoed to be there. Got it done.
__________________
Dan Stewart
1952 CJ3a
1989 4Runner
DanStew is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Vacuum lines? raymeg 84-85 Trucks & 4Runners 0 04-02-2007 06:04 PM
Coolant or water in the vacuum lines(metal tubes) for '85 22RE EGR pcmentor 84-85 Trucks & 4Runners 2 11-10-2006 07:07 AM
vacuum lines j40joe Early Land Cruisers 0 07-20-2006 05:39 AM
vacuum lines j40joe Land Crusiers/full size SUVs 0 07-19-2006 05:48 PM
vacuum lines shortboy2 86-95 Trucks & 4Runners 5 11-24-2005 02:33 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
