22RE Running Rich?
Old 01-26-2011, 07:39 AM
modlite's Avatar
22RE Running Rich?
My 22re has been acting up a little lately and I was hoping you guys could help me pin point the problem. I have noticed a decrease in fuel mileage from 22mpg to about 17mpg first off. Then every now and then when I'm driving around 1800 rpm it will fall flat on its face and just stay at 1800 rpm for a few seconds then start again. Then the last problem it is having is when I go to start it up sometimes, it won't start and I'll have to let it sit then crank it over for a minute or two for it to start. When this happens, you can smell gas from the outside and it smells like it's running really rich. It's nothing that has compromised the reliability of the truck so far just gets annoying sometimes.
Old 01-26-2011, 07:57 AM
snobdds's Avatar
The things I would check first are:
1. Cold Start injector time switch. See if it is in spec.
2. How is the coolant temp. Sometimes if the t-stat is stuck open the engine will never get up to operating temp. The computer will dump more fuel thinking the truck is still cold.
3. Check the timing, both cam and ignition.
Old 01-26-2011, 09:44 AM
sam333's Avatar
Also coolent temp sensor and fuel pressure , fuel pressure regulator.
Colington
03-08-2020 09:51 AM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
Poncho0206
07-10-2015 06:21 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: 22RE Running Rich?
