22RE Rough Idle
Old 01-05-2013, 11:17 AM
smackay's Avatar
22RE Rough Idle
My 1992 4Runner just started idling rough, especially at cold start. Plugs, cap and rotor were replaced about 3,000 miles ago; valves were adjusted at the same time. The engine has 265,000 miles on it, but runs well above 2,000 RPM. Where should I start with troubleshooting? Any suggestions will be much appreciated.
Old 01-07-2013, 10:59 AM
mYnAmEiSmUd's Avatar
It could be a number of things...
look for vaccum leaks
short diag port and look for codes (http://www.4crawler.com/4x4/CheapTri...es/index.shtml)
Throttle Positioning Sensor, TPS, In need of adjustment (http://www.4crawler.com/4x4/CheapTri...#TPSAdjustment)
Consult Factory Service Manual (http://personal.utulsa.edu/~nathan-buchanan/93fsm/)
Good luck. Hopefully other more experienced members will chime in.
Old 01-07-2013, 03:48 PM
Staff
Terrys87's Avatar
Check your fuel filter, and I would do the Seafoam treatment. Clean out the mess caused by the EGR. Make sure all vacuum lines are clear and flowing, especially off of the Plenum.
Old 01-08-2013, 07:46 PM
smackay's Avatar
22RE Rough Idle
Thanks for the input, folks. I will take these suggestions up this weekend.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
montanatruck
02-26-2017 07:07 AM
09-04-2015 09:27 AM
v_man
07-23-2015 04:01 PM
Quick Reply: 22RE Rough Idle
