22RE low idle / hard start
Old 06-30-2015, 06:04 AM
Sandman's Avatar
Just swapped a 22re into the truck. It starts ok cold but idles super low 300 and down. Once warmed up it won't start unless I press the gas pedal a few times while cranking. Drove around the block, has now power. No codes from the EFI system. I've checked for vacuum leaks, egr, new wires, new alternator, injectors have new o-rings. Tried adjusting the TPS, no luck. AFM flapper is moving, O2 sensor is fairly new. Any ideas? I'm racking my brain on this!...searched quite a bit, but no luck finding answers.
Old 06-30-2015, 11:07 PM
jennygirl's Avatar
You probably already checked it but didn't see it mentioned... Have you tried adjusting the idle set screw out?
Also could try timing and compression check. Either could explain a lack of power and funky idle.
Old 07-01-2015, 03:24 AM
Sandman's Avatar
yes, messed with the idle screw,didn't check compression, but I think it's a head gasket now, oil looks like chocolate milk. Guess this engine is coming out
Old 07-01-2015, 09:48 AM
jennygirl's Avatar
Aww boo. Sorry to hear that!
Well, at least you know what the problem is. With these motors, that is 75% of the battle! Idle and start issues can be kinda tricky to diagnose.
Old 07-02-2015, 06:09 PM
Sandman's Avatar
thanks, it's true, I'm relieved to know what the problem is... my fault for taking a gamble on an engine that the seller knew little about... :p
Old 07-23-2015, 08:15 PM
Hawk_man24's Avatar
I have the same problem and my engine was recently rebuilt and installed. I took it in running like a clock, not it is rough and not so easy to start. I am thinking really hard on
maybe trying to get a refund.
Cesarl74
04-23-2016 06:07 PM
Ichneumon
09-27-2015 04:21 PM
94 Newbie
07-06-2015 04:23 AM
slider417
06-22-2015 10:18 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: 22RE low idle / hard start
