22RE horrible gas mileage
Old 07-16-2011, 06:07 PM
Clone of 501's Avatar
So here's my situation. My 1993 truck is a single cab and RWD with the 5 spd. The gas mileage has never been good, but it's really been annoying me with gas prices recently. I've only been driving it for a year, so I mean most parts are still stock.
I tanked it to the full and put on 60 or so miles on it. The tank is half gone though. That's pretty terrible mileage. The idle is fine and everything though.
So what should I be looking at? I read around and it seems a lot of people say vacuum leaks are suspect.
Pic of my truck:
http://img850.imageshack.us/img850/6379/carqz.jpg
Old 07-16-2011, 07:39 PM
BigSwole's Avatar
A hole in the gas tank maybe?
Old 07-16-2011, 07:47 PM
There has never been anything leaking from behind my car. If I leave it sitting, the only thing that drips is the AC.
Old 07-16-2011, 11:15 PM
myyota's Avatar
Lets start with the basics, when was the last time you gave your truck a complete tune up ?. I would start there first, Change the oil and filter, distributor cap/rotor, plugs and plug wires, fuel filter, and the 02 sensor. Use all OEM parts. If the 02 sensor is original and it has a lot of miles on it - it can go bad and cause poor gas mileage. If you replace it buy a Denso OEM replacement, DO NOT buy a Bosch 02 sensor, they don`t work very good in toyotas.
Other things to check would be the timing and valve adjustment.
Old 07-17-2011, 12:37 PM
I changed the oil not too long ago. I'll begin with the O2 sensor in this case.
Thanks.
Old 07-18-2011, 03:12 PM
ranchero's Avatar
The oxy sensor on mine was worth about 2mpg.
Old 11-02-2011, 02:57 PM
eastwood's Avatar
Air filter helped a lot, using the K&N
montanatruck
02-26-2017 07:07 AM
09-04-2015 09:27 AM
pyramid
07-30-2015 10:05 AM
daddio
07-18-2015 10:20 AM
ryerye13
07-14-2015 08:27 AM
Quick Reply: 22RE horrible gas mileage
