22RE hesitates on accelleration when cold, smell like raw fuel
Old 04-07-2009, 08:44 PM
YotaWoRx's Avatar
I have an '88 22RE. When I go to start it when its dead cold, it takes a few seconds of cranking to fire. Then when I goose the throttle it hesitates and seems like its missing. almost like the timing wont advance. it also smells super rich. once it warms up, the hesitation goes away but it still smells rich. the codes 12 and 52 were stored in the ecu. I am stumped. any ideas???
Old 04-07-2009, 08:49 PM
lilgreg46's Avatar
Hook up a pressure tester to the fuel and run it. Check the pressure then shut it off. Watch the pressure it should not drop off. If it dose it will most likley be a leaking inj. That would explain some of the gas smell and the hard start. Hope this helps you...
Old 04-07-2009, 09:13 PM
YotaWoRx's Avatar
if the cold start injector was leaking would that cause it too?
jbv808
08-06-2021 04:47 PM
sandyota
02-04-2021 11:16 AM
Eggslinger
06-08-2019 03:32 PM
TURBOrunnerNM
07-22-2015 11:01 AM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: 22RE hesitates on accelleration when cold, smell like raw fuel
