22re ECU Year
Old 04-17-2012, 04:27 PM
Chocochat's Avatar
22re ECU Year
Hi there, I bought a 91 Toyota Pickup 4x4 and it has a 85 Celica engine in it. I was just wondering if there was a way to know which ECU it is running, Celica or Pickup? Is there a different code on the ECU depending on the year?
Ty!
Old 04-17-2012, 04:41 PM
BMcEL's Avatar
It's behind the passenger kick panel...google the part number.
Old 04-17-2012, 05:59 PM
wyoming9's Avatar
Red face
It could be either one get the part # off the unit.
Depends if they just swapped the electronics from the original engine. or not I think the part # off the igniter would also let you know
Old 04-17-2012, 06:34 PM
Inferno451's Avatar
There are different ECU's depending on the year. I believe in 89' was the switch to high impedance injectors, if you mix that up you can burn up your ecu. There will be a code on the box.
MO transplant
04-23-2023 11:58 AM
mskalmus
05-28-2017 07:51 AM
crashburnoveride
08-28-2015 09:20 PM
Sandman
07-14-2015 12:36 PM
ryerye13
07-14-2015 08:27 AM
Quick Reply: 22re ECU Year
