22RE crank but no start - got fuel and spark
i have a problem. i got a 22re that wont start. i checked fuel and spark i got both. it will crank but no start. what do i need to check
Last edited by waskillywabbit; 03-01-2009 at 07:13 AM. Reason: Title clarity will provide faster help with questions
Welcome to Yotatech.
Do you have a FSM? If not, there are some troubleshooting tips there.
Try this link and see if you can find something in the FSM.
https://www.yotatech.com/forums/f128...-years-156128/
Good luck and please update when you find the problem as that helps future users with the same issues.
have you checked that the fuel injectors are getting the signal to fire?
have you checked that the distributor is installed correctly? ...with the rotor pointing at the proper cylinder?
see i know we have fuel to the filter, but i havent checked yet to see if its at the rail or checked the signal. also we jumped the diagnostic port and got 8 flashes, a pause then 11 flashes, a pause then 2 flashes
Have you been working on the engine- rebuilding or replacing it? What work's been done on it recently?
Here's the codes breakdown-
2: air flow meter signal: VC or E2 open; VS-E2 or VC-VS shorted
8: intake air temp sensor: THA open or short
11: neutral safety switch is on, or TPS IDL signal is off when diagnostic terminal is shorted.
here's troubleshooting of the AFM: http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
here's troubleshooting of the TPS: http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
scharp- disconnect the battery for a few minutes to clear the codes then put the jumper in and go turn the key to 'on' (don't start it) and see if anything comes up. If it does, then that may be something to worry about.
and yeah, I asked earlier but didn't get an answer and xzraygon brought it back up- have you checked the distributor?
yea i checked the distributor. but i did some volt testing and the tps fully open is supposed to have 4 - 10 volts and it only and 1.7v i think i found the problem. would that cause it not to start
While waiting for that... do you have continuity between E2 and IDL terminals (3rd and 4th from the top) with the TPS installed and the throttle closed?
(those are the ones that will throw the code)
