22RE coolant drain problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-22-2006, 07:25 PM   #1 (permalink)
GT88Yota's Avatar
Send a message via AIM to GT88Yota
As the title says I am having a bit of a problem with the coolant drain on the 22RE in my 88 pickup. Well I removed the plug from the block and nothing happened, so I used a mirror to look inside it and it appeared as though some sort of plug was in there which required an Allen wrench to remove it. So I grabbed what I though was the proper sized Allen wrench and tried to remove it, nothing happened. Keep in mind it was pretty gummed up so it was hard to see exactly what I was dealing with. So in a fit of frustration I grabbed a flat headed screwdriver and pushed against the plug. It moved with relative ease and coolant came pouring out.
The problem I have is it does not appear to have returned to its original position. Should I not worry about it or is there some secret to taking it out?
GT88Yota is offline
Old 12-23-2006, 07:12 AM   #2 (permalink)
InternetRoadkill's Avatar
I think what you saw was simply old scale that had built up behind the plug you removed. (?)
InternetRoadkill is offline
Old 12-23-2006, 02:45 PM   #3 (permalink)
GT88Yota's Avatar
You're right, thats what it was and I cleared it out. Thanks.
GT88Yota is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
22re Coolant problem RustBucket 86-95 Trucks & 4Runners 7 12-15-2006 06:22 AM
coolant drain vs flush jordanirvin Maintenance & Repair Archives 2 10-29-2005 10:48 AM
Coolant drain on a 2.7l block? Please help. Foch Maintenance & Repair Archives 3 06-09-2004 12:00 PM
coolant drain plug Nathan 95.5-2004 Tacomas & 96-2002 4Runners 4 10-18-2003 10:14 PM
Coolant Drain Plug Location John Peters 95.5-2004 Tacomas & 96-2002 4Runners 4 12-06-2002 09:11 AM
2009 InternetBrands, Inc.
