22RE bogs on me.
Old 12-20-2005, 01:23 PM
4Runnerboy's Avatar
22RE bogs on me.
Hey all, I just went muddin this morning and I had to call it early because two problems started to arise, 1: my throttle started to stick again, and 2: everytime I try to gas the truck around 1300-2100 RPM the engine bogs and near about dies, I changed the oil when I got home, because it needed to be done, and just incase I somehow got water into the engine, I'm going to go try to take the spark plugs out and crank the engine with them out, but should I do anything else? Thanks in advance, and if I need to explain anything more let me know.
-Jack
Old 12-20-2005, 02:50 PM
93Yota's Avatar
Is it carberated? Sounds like a jetting problem to me, but I'm not a toyota expert. Could be another problem all together but certainly sounds carb related to me. Is this something that just started or have you noticed it before? Could be something as simple as a clogged air filter not allowing enough air into the motor
Edit - I'm an idiot....just saw you posted for a 22RE, not a 22R. Could still be an air filter though...plugged injectors maybe?
Old 12-20-2005, 04:48 PM
tc
tc's Avatar
Spray WD40 in the cylinders when you pull the plugs. Everyone DOES know WD40 stands for Water Displacement formula 40 right? It's not really designed as a lubricant...
Other things - fuel filter or bad gas. Mine behaved like yours is - fuel treatment and fuel filter and all was good.
jasonty
41
12-23-2018 01:00 PM
Yota.Jay
10-24-2015 08:41 AM
shadowbirdie
07-21-2015 10:38 PM
Odin
07-15-2015 09:28 PM
Quick Reply: 22RE bogs on me.
