22r jumpy timing
Old Dec 17, 2007 | 05:32 PM
85erxxx85's Avatar
Angry 22r jumpy timing
Hi well stuck again posted earler about the new hg job and still steam... well steam is gone and all is well.. now the friggen ing timing is all over the place.. if i set it with the advance pluged it will go to 0 but it will jump a bit and then if i get it set and plug the advance back on and it will idle fine. It still jumps eraticly... has no power under load drove it around the block and it just has no power at all through the gears. Please help me fix this thing i want to start driving. It has a webber carb and the egr is disconected
Old Dec 17, 2007 | 05:44 PM
ozziesironmanoffroad's Avatar
that sounds like your timing chain. the dot on the harmonic balancer is supposed to stay in one place. how longs it been since you replaced the timing chain?
Old Dec 17, 2007 | 05:48 PM
85erxxx85's Avatar
just replaced it with a seel guided kit when i did the HG job less than a week ago
Old Dec 17, 2007 | 06:28 PM
85erxxx85's Avatar
any body got any ideas????
Old Dec 17, 2007 | 06:59 PM
85erxxx85's Avatar
could i have put the new chain on wrong?? The mark on the pully lines up with the mark at 0 on the pump while the cam sproket mark is at 12 oclock so im not sure why the mark is jumping under the light... And the truck has no power under load??
Old Dec 17, 2007 | 08:02 PM
85erxxx85's Avatar
If this is the case could that explain the loss of power and hesitation under load?? All was well before i did the timing chain and HG so this is all new stuff that i need to get tuned and fixed Im not to familar with distributers and or bushings so the bushings are whats causing the mark to jump... Is the mark jsut jumping or is it affecting the timing at the time it jumps,,, the moter sounds fine at idle even under the light when its jumping... thanks for the help i deff need it
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
87blyota
Jul 10, 2015 04:31 AM
