22r backfire
Old 01-27-2011, 08:38 AM
Z's Confederate Toy's Avatar
22r backfire
My 87 has a horrid backfire when I let off the pedal to shift. I have reset the mixture screw, timed it, checked the vac lines and I still can't seem to figure out what might be causing it.
Old 01-27-2011, 08:47 AM
It also seems to be running super rich. Like passing raw fuel into the exhaust.
Old 01-27-2011, 09:57 AM
xxxtreme22r's Avatar
were you working on it lately? ie, plug wires, dizzy, timing? Tooth off on dizzy and/or crossed wires comes to mind. Any power loss? Backfiring through exhaust or carb?
Old 01-27-2011, 10:00 AM
camo31_10.50's Avatar
mine used to backfire out the exhaust, would shoot a 4ft flame out of my turndown... bahahahaha. good way to scare some people
Old 01-27-2011, 10:01 AM
oh i didn't add any tech lol....mine was because my carb needed to be rebuilt and adjusted
Old 01-27-2011, 10:12 AM
I put a junkyard motor in it about a month ago. But it backfired before that. We did the timing right after. I had some vac lines reversed but they are all straight now. The plugs are relativley new along with the wires. It backfires thru the exhaust. Shoots flames like camo said his did. It also smells like its dumping raw gasoline out the turndown.
Old 01-27-2011, 10:20 AM
sounds like the aap diaphram is busted. pull the vac line off it and see if fuel dumps out of it. This might only affect the engine if it's cold but not warm As the vacuum to that is controlled by a bvsv.
only other thing I can think of is a sicking float.
same carb as the old motor right?
Old 01-27-2011, 10:26 AM
Yeah same carb. Ill try that and see whats up.
Old 01-27-2011, 10:34 AM
Now that you say sticky float. It does become flooded after driving it a while and I turn it off and let it sit. I tried the AAP, and no fuel dump.
Old 01-27-2011, 10:41 AM
I would lean towards float then. Might as well rebuild it.
Old 01-27-2011, 10:44 AM
Yep, for sure. I have a rebuild kit sittin in the shop. I will prolly tear into it tonite. Thanks for the help.
Old 01-27-2011, 10:56 AM
no problem, my advise does not come with a warranty though. Hope you get it all sorted out.
Old 01-27-2011, 11:37 AM
It still helps. Better than a sharp stick in the eye lmao
Old 02-10-2011, 01:30 PM
Still backfiring.
I replaced the carb on my 87 with the one off of our 85. The truck runs wayyy better but still backfires when I let off of the pedal at higher RPMs.
Old 02-10-2011, 02:13 PM
justin_4runner's Avatar
how are your mufflers and cat? also are u sure that the carb is not dumping gas in still after u let off the pedal? my 87 use to pop due to me putting an after market cap and muffler on that where high flow. not enough back pressure i guess or something..
Old 02-10-2011, 02:19 PM
They are both old. The muffler has a split from backfiring and im pretty sure the cat is the original, all in its 415XXX mile glory. Im sure that has something to do with it. The carb is not dumping fuel still after I let off of the gas. It ran 100% on the other truck.
Old 02-10-2011, 02:26 PM
Timing issues maybe?
Old 02-10-2011, 03:27 PM
No we threw a timing light on it today to check it. All was good.
Old 02-10-2011, 04:09 PM
0 degrees right?
Old 02-10-2011, 04:43 PM
He says no. Is that what its suppodabe? I not the best timing guy, I have my old man do it while I learn. Hes use to Ford though.
Quick Reply: 22r backfire
